Shop Floor Talk (http://www.shopfloortalk.com/forums/index.php)
-   Fabrication (http://www.shopfloortalk.com/forums/forumdisplay.php?f=13)
-   -   Need help, swaging die. (http://www.shopfloortalk.com/forums/showthread.php?t=47161)
Walker 11-28-2016 06:55 PM
I am building another cable rail. This one has several hundred terminals. I have been using a small hydraulic hand held unit to swaging the terminals. It is wore out, and takes 3 passes to fully swage each terminal. The dies are also wore out.
So, looking to make a new set of dies to use on the punch end of my ironworker. I usually just weld them to the end of some steel 2x2 pieces the I mint in place of the punch.
It would be easy enough to take two pieces of heavy flat bar, drill a hole down the seam, and be done. However, I don't have access to S7, or the like without a two hour drive.
Any ideas as to common materials (springs, tools) and methods (I can forge, just out of fuel) that might work?
Walker 11-28-2016 07:02 PM
Just typing it in has spurred some ideas. I have some broken ironworker punches that are the perfect size for dies, just need to figure out how to put in the half round groove.
gimpyrobb 11-28-2016 07:10 PM
Any pics of the old components?
Walker 11-28-2016 09:44 PM
1 Attachment(s)
Just a cheap hydraulic press with hex dies.
1/4" half round would work just fine.
digr 11-28-2016 09:50 PM
I don't have access to S7 What does this mean S7? Why can't you do the flat bar trick?
milomilo 11-28-2016 10:04 PM
How much tension on the cable do you expect? How much pressure did the old tool have?
Walker 11-28-2016 10:22 PM
I don't think the punches will work, just not enough clearance at the punch holder.
I did stumble across an old set of shear blades that would work. If I can figure out a way to semi accurately grind a 1/4" groove with an angle grinder it would work.
Maybe clamping a couple flat bars on each side of the groove with some sort of depth stop on the grinder. May have to sleep on it.
Walker 11-28-2016 10:28 PM
Digr, the S7 is a hardenable steel, not sure how well mild would hold up. Since I do a couple rails a year it would be nice to have a tool that will hold up.
The old tool had 20-40 tons iirc, but they were Chinese tons, not American tons, so I don't know how hard it would really squeeze.
Norm W 11-28-2016 10:31 PM
How about grinding the desired size "hole" in the blades of a large set of bolt cutters? You might have to swage in a couple of sections as it wouldn't be a wide set of jaws.
Walker 11-28-2016 10:48 PM
Norm, when you have hundreds to do it gets old fast doing them by hand. I can stomp a peddle that many times without thinking twice.
