Shop Floor Talk (http://www.shopfloortalk.com/forums/index.php)
-   Fabrication (http://www.shopfloortalk.com/forums/forumdisplay.php?f=13)
-   -   cutting a rim in half question (http://www.shopfloortalk.com/forums/showthread.php?t=45035)
Destructo_d 11-29-2015 11:40 PM
I would like to cut a rim in half.. what I want to make is a half circle... I am going to make one of those tire rim fire pits.
With the fact that there is a hole in the middle, what would be the easiest way to measure and mark it so I can cut in in half... for that matter... How can I do it on any piece of pipe or other item that is round?
Thanks
digr 11-29-2015 11:56 PM
Just take a piece of emery cloth and rap it around and mark it. will be close enough in this case.
threepiece 11-30-2015 09:30 AM
1 Attachment(s)
Is this what you want?
milomilo 11-30-2015 09:35 AM
Simple solution.
toprecycler 11-30-2015 12:32 PM
1 Attachment(s)
I think he wants to cut it the other way.
Take a straight edge and hold one end down on the outer edge of the rim. Take a tape measure and measure across the center perpendicular and line the straight edge up at 1/2 of the diameter of the rim. (If the rim measures 16", then line the straight edge up at 8") Mark both sides of rim where straight edge is. Take a string with a nut slipped on and hold the string on the marks on the outer rim, and let the nut weigh down the string (provided the rim is laying flat on a level surface) and the string will show where to mark the rim at the center hole. Connect the marks the best you can and cut away.:)
dubby 11-30-2015 01:48 PM
That's what I thought as well, looking to find the diameter points...
Use a right angle:
http://www.mathopenref.com/constcirclecenter2.html
duckman903 11-30-2015 05:49 PM
Put it on the floor make a mark on rim roll for 1 rev. measure divide in half mark rim , cut done.
DeepSeaDynamo 11-30-2015 06:00 PM
How man bolt holes does the rim have? If its not 5 you can use the holes to line up a straight edge. There are many many ways to skin this cat.
digr 11-30-2015 07:12 PM
1 Attachment(s)
Use a square
Lew Hartswick 12-01-2015 07:29 AM
To just how many thousandths do you want to get this "Half"? :-)
...lew...
