JR Welding Tools
Old 03-31-2017, 11:48 PM
Default $55 OOPS--30A Canister...
I was at the LWS the other day picking up some gas (Ar 125 $46) and I remember I'd been needing a spoolgun canister since it slid off the bench about a year ago. In a pinch, I epoxied it and it has been working fine BUT I still wanted a "spare" just in case.
The entire canister is about $101 inc. post, clear cover and other hardware. Just the bare canister housing cost me $55. My guy happened to have one in stock that someone ordered and never picked up. Farking fiddyfive dollas for a piece of plastic.
On the bright side the old one took the epoxy well. I think I used clear 2-part on the rough surface where it broke and 2-part (black/white) grey over that after I scuff sanded the surface to be bonded.
I believe the part number for the complete can is #132230
ID:	138634   Click image for larger version
Old 04-01-2017, 09:57 AM
Yeah, that plastic stuff on the 30A has always made me nervous - I keep .035" L56 wire in mine for "aerial" work(personal projects) - work on gravel mostly, hard to move the 252 without putting it on a trailer (thanks, Miller, for doing away with the lift eye ) -
When I saw what they want for a COMPLETE 30 foot lead OR a 20' replacement torch for my PM45 (either one's around $400), I ordered a couple of these
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
makes the leads a little bit stiffer, but at 1/10 of the cost to replace, I'll take it... Steve
Old 04-01-2017, 05:20 PM
TEK's Avatar
TEK TEK is offline
That old cliche still stands--
' there is nothing quite so permanent as a good temporary fix'
That is why guys (or gals) that can 'deal with it' will always be around. Anyone can just swap out parts..
I think someone here has that as a sig line..
-----DozerDan
Old 04-01-2017, 08:25 PM
"If it ain't broke, don't fix it!"
and
"If it can't be fixed, I don't want to work on it..."
Keep in mind I've been using the 30A with repaired can since I dropped it about a year ago. Probably about 15-20 spools so far. But Murphy's Law dictates that if you have a spare, you will never need it!
Old 04-02-2017, 06:26 PM
Scrapper Greg's Avatar
One of those 3D printers might make a good investment for something like this.
MAGA
Old 04-02-2017, 07:58 PM
TEK's Avatar
TEK TEK is offline
and
Or the ever popular 'you really think I can't make it worse?'
-----DozerDan
