Old 05-29-2017, 04:03 PM
Default Gehl 4610 skid loader repair
Finally decided it was time to tear into the reason I lost right side drive wheels on my gehl skid loader. They stopped moving about 4 or 5 years ago when I was moving some junk out of the pole barn in the winter time. I remember that it was a pain trying to get the loader back to the shop with only the left wheels driving.
I was afraid it was the hydraulic motor that went out, and after talking with a hydraulic repair shop got sticker shock for fixing it if that was what it was. More than I paid for the loader itself. So it got pushed to the side for a while. I knew it was going to be a while for me to get it fixed after I tore it down and figured I better wait until I cleaned out the shop to get it inside.
Cleaned out the shop last year somewhat, and now I put the loader near the shop and still tore it apart outside. Pain having to cover it up when it rains.
It sure is a pain working on it. I sure would not want to do it for a living, but the mechanics would earn their money for sure.
Finally got the motor out today, and it is the drive gear that is stripped. And could use a bearing too. Will be checking on getting parts tomorrow. Looks like the gear is about $90, but will call a local parts place to price check.
ID:	139552Click image for larger version
ID:	139553Click image for larger version
ID:	139554Click image for larger version
ID:	139555Click image for larger version
Old 05-29-2017, 04:07 PM
Some more pics The last two are pics before I started to remove lines to get to what I needed.
ID:	139557Click image for larger version
ID:	139558Click image for larger version
ID:	139559Click image for larger version
Old 05-30-2017, 10:07 AM
It sometimes startles me that when you tear into a machine like that & get down to the nitty gritty of how they move, its still just gears & chains that make the world go 'round.
I want to go home!
Old 05-30-2017, 10:15 AM
But but but...where's the cow manure ? Every one I had to work on had
it deep in there, and covered in hyd oil too...
Old 05-31-2017, 08:02 PM
Need bearing advice.
Called germanbliss equip to order parts. I think I had downloaded the parts manual from them and they showed the parts online with pricing so I figured I would give them my business. They are shipping the gear and gaskets I need, but was out of stock for the bearing I should replace. Going to be out for 90 days. I would like to get this put back together sooner than that, so trying to source the bearing elsewhere.
#s on the bearing "Peer Romania. 6012 RS"
MCMaster Carr wants $125 to $145 for one. eBay seller came up with 2 for $21. I am cheap, but do I want to go this cheap? This thing isn't the fun to tear apart. The old bearing sounds rough, and probably should be changed while I am fixing it.
Anyone else has any suggestions to get bearings from? Click image for larger version
ID:	139588Click image for larger version
Old 05-31-2017, 08:43 PM
Default Motion Industries
I've used these guys in the past (Seems like they used to be called moore bearing IIRC)
https://www.motionindustries.com/pro....jsp?q=6012-RS
Old 05-31-2017, 10:42 PM
It is the shaft that took out the sprocket, if you don't replace the shaft its not going to last long and you will need another sprocket.
the RS on the bearing is likely referring to what the bearing is sealed/Shields and which sides.
maybe a rubber-seal on one side and a shield on the other.
Old 05-31-2017, 11:12 PM
Samcord Samcord is offline
I don't know one brand from another, but there are a bunch of these on Amazon. I'd probably call a local industrial supply house and see what they might have available. Click image for larger version
Old 06-01-2017, 01:09 AM
So Brian, if one side went out, how much wear do you see on the other? After all that time to pull and remove things to get at a problem on one side....................I'd be thinking about pre-fixes.
Looks like one involved job with all of the hydraulics alone. But you guys just amaze me with abilities.
Hope the parts find their way to your house in a timely fashion.
Old 06-01-2017, 06:46 PM
I would agree that the shaft doesn't look the best, so I did check on a replacement shaft. Obsolete part. The motor is also crossed to a new number. Only $1058 to replace it. I think I am going to run it like it is and see how long it lasts. I will try to baby it too. At least it is not a machine I use daily to make my living. Just makes my life easier around the yard.
