Old 05-31-2017, 02:06 PM
SmokinDodge's Avatar
SFT Executive Chef
Originally Posted by Walker View Post
IH motors don't like advance, factory spec is 0* at idle. I am suspicious of too much overall advance, but can't figure out a way to measure it yet, and have to figure out how to adjust the vacuum can.
You need to put cylinder #1 at TDC and mark the dampner. I've seen more than one that the outer shell has turned and the timing marks are waaaay outta whack.
If you get or borrow a fancy timing light they have a dial you can advance the timing light to check to total advance.
Have you verified the accuracy of your gauge?
Old 05-31-2017, 04:15 PM
RED caddy's Avatar
Da Chief
Yep, timing is the usual suspect in over heating I had a 4 cyl, (half of a 350) and the same V8 like yours.
Take a really close look inside the distributor, check the centrifugal and vacuum advance parts, as they are prone to rust up. If you can find a shop with an "old school" sun distributor machine, this is the most accurate fix. most GM vac cans can be adjusted with a 1/16 th allen wrench thru the vac port. Careful a little turn is a lot.
RED
Old 05-31-2017, 04:30 PM
Originally Posted by chumly2071 View Post
Shroud needs to be as close to the blade tips as possible. 1/2" at most. Fan should also be mostly in the shroud, with shroud tight fitting to the radiator...I'm assuming too that the fan is spinning the correct direction to be a puller.
+1 on this ^^^^
The condensor shouldn't be an issue as long as the fins aren't clogged with oil, bugs or leaves and besides, it is not (yet) transferring any heat. The condensor should be "sealed" to the radiator with its own side shrouds but this shouldn't matter as the A/C is not yet hooked up.
Go through with an IR temp gun (HF, $20 or so) and check temp of the various components, top and bottom of radiator, etc.
Perhaps you'll need to add an aftermarket, thermostatically controlled pusher electric fan...
My limited IH experience makes me think that the V-8s were timed on #8... I could be wrong but just one of those things that stuck in my head.
PS: and timing should be checked with the vac. adv. disconnected and hose plugged. I would use ported vacuum but I don't know what IH used. The mech. adv. can be checked easy enough by bringing the revs up with timing light hooked up--you should see the mark advance up the scale as revs are increased.
Old 05-31-2017, 07:22 PM
I believe the fan is in the proper orientation, I think it says engine side on the hub, but it is a pain to remove to check, but based on pictures of other fans I think it is right, and it is a puller.
Timing is set off number 8, and I don't think IH balancers can spin, but I will double check. I did try retarding it more after it was set at zero and it starts to run like crap.
All parts are brand new, so nothing is plugged
Old 11-18-2017, 10:04 PM
I haven't updated this thread recently. Back when I had the truck saga I decided I had to get it fixed so I would have a set of wheels.
I ended up pulling the 15" 5 blade fan out. I had an 18" fan, so I installed that. It was not without pain though. I had to change my power steering pulley as the fan interfered with the belt. I had a two groove pulley that I put on then moved the belt to the inner groove. This kind of sucked because it used the crank groove that was for my air conditioning. I butchered my freshly made aluminum shroud and got it back on. Fired it up and went for a drive.
It cools perfectly now. I will likely end up changing it out for a 17" fan as the are some clearances that I am not real comfortable with running it off road. I will also likely put in a four inch wider radiator. This is to get the side tanks out of the way of the blades and allow a little more clearance to move the fan forward. I will also end up moving the engine backward about a quarter inch so that I can reclaim my air conditioner pulley.
