Old 06-01-2017, 11:35 PM
Like Walker said, ABS is just an "add-on" (sort of) and if it malfunctions because of a speed sensor, it fail-safes to "off". The components should be bled on a regular basis just like the rest of the braking system but that is rarely done due to special tools/scanners needed (usually).
The main problem I've seen with ABS over the years are fluid leaks due to corrosion, etc.
