JR Welding Tools
Old 06-04-2017, 08:23 AM
FWIW My maintenance friend has run 575 (that's 600 volt) motors
on 440 for years, no harm done.
True.
I have run 50 cycle 3phase 460 volt motors on 600V 60 cycle with no problems. You can go over and under voltage about 20 percent without problems but in an overload you will smoke it faster in an overvoltage situation. These were put on water pumps with very little head.They were Polish built, and I got a pallet of 6 of them for $50 that terrified the locals because it said 50 cycle. Big heavy motors with lots of iron and copper.
A 600 volt motor will run on 220V at about 1/3 rated power, and all I want is to check bearing noise.
Herodotus
Old 06-04-2017, 09:41 AM
camdigger's Avatar
Roving Reporter
True.
I vividly remember simply swapping the drive pulleys for smaller ones to use 50 hz motors on Swedish equipment for use with North American 60 hz power. The overall speed of the machine was to be kept in very narrow limits. They were very careful to get transformers of correct output voltages though, as there were other systems on those machines that were sensitive to the voltage they were fed.
I also vaguely recall motors that would run on different feed voltages by switching from running the windings connected phase to phase (known as Delta IIRC), or phase to neutral (known as a Star connection IIRC). I'm sure Terry L or someone more up on industrial electrical stuff could clarify or verify.....
Old 06-04-2017, 11:45 AM
moe1942's Avatar
moe1942 moe1942 is offline
Voice of Experience
You could convert it to line shaft operation and run the line shaft off an antique tractor...
I was thinking steam.....
Old 06-04-2017, 12:00 PM
He does have a lister that could drive the line shaft .
Old 06-04-2017, 04:32 PM
That's what the Amish around here use.....
Old 06-08-2017, 09:51 PM
Hope you get this thing slinging chips soon Gerry.
Looks like a keeper.
Old 06-09-2017, 08:59 PM
Another rain day so I was inside piddling around on the mill. Cleaning up dried on flood coolant does not work well with varsol, but it does soften it, and then a wire brush moves it. I pressure washed it with soap when I got the machine home and drained the sump.
The little spots in the nooks and crannies need a easy way to melt this shit. Alcohol? Brakekleen? Gas?
Herodotus
Old 06-09-2017, 11:03 PM
I've used brake cleaner on some of that stuff, but it can also soften paint, so test it first.
Some strong commercial cleaners will also do it, I think it's a matter of finding the 'right' active ingredients.
Time for a new signature line!!
Old 06-10-2017, 03:41 PM
Gonna try ZEP Citrus degreaser as recommended by some guys on Practical machinist.
Today I took off the motor, and that appears to be the source of the noise. You can turn it over by hand, but as soon as you do you can feel the grinding and the shaft will not spin freely at all.
Herodotus
Old 06-10-2017, 07:48 PM
Canadians!! <sigh>,
spill a little Mt Dew Code Red on the hardened crap, it will be gone in no time!!......
