Old 06-06-2017, 04:18 PM
Default Gasket Maker
Going to be changing the rear differential oil in a couple weeks on the Dodge 3500. Question is instead of buying a gasket I'd like to use the silicone gasket maker or should I anaerobic gasket maker?
Old 06-06-2017, 09:46 PM
gimpyrobb's Avatar
Just trace the cover and cut one out.
Old 06-06-2017, 10:23 PM
That's what I usually do, but thinking about doing it different this time.
Old 06-06-2017, 11:10 PM
I used permatex ultra gray on my GM 2500 rear end cover. its held up ok so far.
Old 06-06-2017, 11:32 PM
That is one vote for silicone. I have used the anaerobic before and it is real easy to remove. Expect I will never remove this cover ever again though.
Old 06-06-2017, 11:47 PM
TEK's Avatar
TEK TEK is offline
I've tried it both ways but I pretty much believe in the old school way, CAT Greenshit to glue the gasket to one side, CAT Redshit to seal the other side. .
-----DozerDan
Old 06-07-2017, 12:02 AM
Is the CAT stuff silicone?
Old 06-07-2017, 12:43 AM
I use silicone, no gasket, just like all the automakers. Never had a lick of trouble with it.
Old 06-07-2017, 01:14 AM
TEK's Avatar
TEK TEK is offline
No, but it certainly works...
The green is a glue and the red is similar to Gaskacinch, kinda slimy, snot like...
-----DozerDan
Old 06-07-2017, 07:00 AM
alchemist's Avatar
I have never had a problem with silicone. I think the anarobic stuff is for joining machined surfaces.
