JR Welding Tools
Old 06-07-2017, 08:20 AM
Expect I will never remove this cover ever again though.
yep, things I have heard that one might believe. lol Chris, over the years I've mostly seen the black RTV's used on chunk covers etc. and sparingly at that.
The good, the bad and the ugly of using RTV's and other sealants for form in place of gaskets is just how much of the stuff is used in lieu of a cut formed gasket. Some being hard paper type to a more rubberized type of material.
I've been privy to folks trying to seal val covers, m/c engine cases etc etc etc. with the thought being the more sealant used the better it will seal.
Simple things like using a special type of thread to seal engine cases on recip aircraft engines, silk comes to mind and have used the same material on some of the engines I have around the farm.
I've sealed engine cases on my racing m/c engines using very fine fishing line with good results to keep tolerances to a min.
When I do use an RTV for gaskets I always form a gasket of a particular thickness, letting it cure and then wiping on a thin film and putting things together.
If any here work on Detroits and have seen the gaskets used for the drive covers, the red sealant that is on said gaskets ready to install. I do about the same with or without the use of a hard/soft gasket.
Nothing worse than pulling a pan and checking the pump screen and finding errant bits and pieces of squeezed out RTV and sealants that traveled through the engine and it happens all the time.
Old 06-07-2017, 08:30 AM
Eggzachary LW....
Remember....for all that RTV you see squeezed OUT, the same got squeezed IN....
I like using a paper gasket, in which I apply a very thin smear of RTV both sides
(so thin the blue stuff looks clear after smoothed out) and like you, let
it tack up (gets a skin on it) for even less "squish out".
Old 06-07-2017, 08:56 AM
Originally Posted by Walker View Post
I use silicone, no gasket, just like all the automakers. Never had a lick of trouble with it.
2nd vote for silicone. I too have used it many times, but always sparingly.
Originally Posted by alchemist View Post
I have never had a problem with silicone. I think the anarobic stuff is for joining machined surfaces.
I have used the anaerobic for non machined surfaces too and it worked well. More expensive than silicone, but easier to remove later.
I too like to use a thin film and let it set to reduce squeeze out. Never had one leak that way.
Eggzachary LW....
Thanks all for your input. Like Red Green says "I'm a man, but I can change, If I have to, I guess."
Old 06-07-2017, 09:05 AM
Director: Fish Seduction
Another silicone user here. I'm probably not so precise with it, but it's easier and suits my needs.
I pull the cover and clean off the cap real good while the rest of the diff is draining out. Usually I use one of the green-rubber die grinder surface prep pads. It's easier than scraping. If I want to get real fancy, I'll lay the cap down and spray paint the outside while I have it off. Once it's dry to the touch I flip it over and spread the sealant on the lip in a medium thickness and then spread it all out flat, covering the holes and all.
Then I do whatever needs doing to the diff case itself. Finish draining, wipe, clean the surface, repair--whatever. By the time I'm done the sealant on the cap is usually good to go. Depending on how hard the rubber has set, I'll poke a hole through the bolt holes, but usually it's unnecessary. I bolt the pan back on in a star pattern, like ya do a tire, then go back and snug it all down the same way.
Then refill.
I've been reading up on how to change out the limited-slip clutch discs in my old Bronco rearend here lately. Never have done that one before, and I think I have a bigger issue with the tone ring in there as well. When I hit 75mph the speedo starts bouncing around like crazy and I can't use the cruise control. The engine surges/idles too fast to keep the speed constant as it's trying to keep up. It has a speed sensor in the top of the housing with a little magnet or something I've replaced twice trying to fix the issue. It ain't worked so it must be on the inside
www.nfpd.us
Old 06-07-2017, 11:02 AM
Then refill.
My Dodge has something new to me too. Along with the 85/140 I need to add a friction modifier too, since I tow a lot.
Not real fond of the new lube requirements they have come up with the last 15-20 years. Everything has to have it's own lube specs of the unit fails. I am convinced that they could design the gear innards and seals so everything could use the old gear oils. No doubt in my mind it is a money racket by the auto makers.
Old 06-07-2017, 11:23 AM
A limited slip in Texas ?
Learn sumthin' new everyday here....
Old 06-07-2017, 07:45 PM
alchemist's Avatar
The friction modifier is only for limited slip/posi type diffs with the friction clutches. As far as I know.
Old 06-07-2017, 08:14 PM
Yamabond #5
Old 06-07-2017, 09:33 PM
Yamabond #5
+1 on the Yamabond #5, works great for VW cases.
Old 06-07-2017, 11:26 PM
SmokinDodge's Avatar
SFT Executive Chef
Yamabond #5
Good luck. Last time I tried they said it was special order.
It is nice to have a tube or two on hand for those fuel related fixes.
I'm not a fan of "just silicone". The orange, red, black and blue silicones always leak after a period no matter what.
I have used loctite 5699 with alarming success, second only to international grey sealant. The IH grey when used on an oil pan would grab it tight enough to distort a stamped steel pan on removal. Anymore most late models are glued together. A Duramax doesn't have valve cover gaskets, just uses 5699. Of course it's designed to be that way.
Cummins specs the 5699 and it's some dang good stuff. Of course your only trying to seal a diff, a heavy grease would almost work........
