Old 05-30-2011, 12:27 AM
TxDoc TxDoc is offline
Question Correct Order for Air Compressor Filter/Regulator
I have a little Campbell-Hausfeld 60 gallon compressor. I am installing a new separate filter and regulator. Should the filter come first, before the regulator? Or, does it not matter?
Thanks
Old 05-30-2011, 12:32 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
I always put the filter first, to keep contaminants out of the regulator.
Dave
Old 05-30-2011, 02:48 AM
Thumbs up
Thanks Dave Lee, I appreciate the help. On a side note, when I first saw Dave Lee....I thought I was seeing David Lee something else for a last name, and I thought I had seen you at Reunion Arena in Dallas, TX several years back! I was going to ask how Eddie, Alex and Michael were doing.
Thanks again.
Old 05-30-2011, 06:16 AM
I put the compressor first then filter then a tee with one leg regulated and the other at tank pressure that way I can select filtered air with or without the regulator
Old 05-30-2011, 09:34 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
TxDoc, first a good full port ball valve then a tee with a air chuck then the filter, then the regulator, and finally the oiler If required.
Most of the valves I have seen on compressors are cheap ones that start to leak through before long. I install valves as many places as I can to be able to have air if I need to work on part of the system.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 05-30-2011, 10:11 AM
Dan.
Dan,
What brand do you use?, most of the time I use Apollo(s).
Old 05-30-2011, 01:50 PM
Lu47Dan's Avatar
Dan,
Jack, yep Apollo valves in everything from sweat to threaded, and brass to SS. They have given me the least amount of trouble over the years of any brand.
Dan.
Hobart 175 Mig
Craftsman O/A set
Old 05-30-2011, 01:52 PM
Dan.
The ones I hate are the Nibco ones, real cheesy
Old 05-30-2011, 11:01 PM
I use the Italian ones
WOG 600PSI
Old 05-30-2011, 11:15 PM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
I set mine up in the Magic Garage, with a ball valve, a union so I can remove the stuff for maintenance. Then a t fitting for regulated nonlubricated air. I have a combo filter regulator. If seperate units put the filter first. Then I have a lubricator for running air tools. My compressor is a two stage, so tank pressure is above 150PSI. I don't have a unregulated connection
Jim the Shop Rat
From Jim’s Magic Garage®
