Old 10-11-2012, 08:47 PM
akabull's Avatar
akabull akabull is offline
Maine-iac
Originally Posted by rickairmedic View Post
One other option that none of us have tossed out yet would be to check pricing on renting a pull behind engine driven compresssor and blaster ( at least for doing the frame ) . You might spend less initially and actually get the frame done in 8 hours .
Rick
Good idea! I'll swing by the rental place on the way home in the morning.
Chris in Maine
Old 10-11-2012, 11:13 PM
problem with having it done by someone, is that it is a daily driver.
Chris, I was assuming this was a cab/bed off chassis blast.
I've never done this for my own very good reasons that I will not go into here.
Bottom line, there is no way your going to control this blasting without risking severe damage to everything on and around that frame.
My 2cents? A bad bad idea about to happen. YMMV
Old 10-12-2012, 02:15 AM
akabull's Avatar
Maine-iac
Hiway,
The cab is still on the bed was removed a couple of months ago due to severe rot and it would not pass inspection.
I have been putting off building a flat bed until I can do something to prevent the frame from rusting any further.
Here is it's current condition
Name:	redneck truck.jpg
Chris in Maine
Old 10-12-2012, 03:10 AM
If you go fast around wires you will be ok. If brake lines weak you will find it.Cover with duct tape the vent on the differential.With a commercial unit and 165 cfm compressor about 2 hours to commercial about 4 to white metal .Heavy plastic the glass use duct tape to hold. you will turn around at wrong time and get them.Use a funnel with a screen in it to fill the round top type home blasters .Check some of the lumber yards. Menards has a good fine grade silica used as a sand in paint that works good.$4 for 50 pounds . 1 use pla about 500 pounds .If you can save and screen,you can get about 3 runs through then scrap or save for body parts with good stand off to control warp age. Good luck have fun .
Old 10-12-2012, 07:04 AM
22-W's Avatar
22-W 22-W is offline
Originally Posted by akabull View Post
Hiway,
Wow! Your fenders came from the same place as mine.
Old 10-12-2012, 06:43 PM
akabull's Avatar
Maine-iac
Actually I blatantly stole your idea I thought it was great! I didn't realize they were plastic until I got to Lowe's. Which was even better than the galvanized ones I was going to get. They will stay on the truck even after i get the flat bed built. I will notch them to fit over the springs however so they fit up against the frame, that way they won't stick so far out past the tires. This was a quick and dirty job to get my inspection sticker. The mud flaps are cut from the old rubber tail gate mat
Chris in Maine
Old 10-12-2012, 06:46 PM
akabull's Avatar
Maine-iac
Thanks for the advice! I hadn't even considered accidentally swinging toward the windows
Didn't get to the rental place this morning...forgot with all the action at work last night. Try to do better in the morning
Chris in Maine
Old 10-14-2012, 12:42 AM
akabull's Avatar
Maine-iac
$165/day just for the compressor. I stopped asking after that.
The compressor was a beast though, 45 cfm. This was the smallest compressor they had that was rated higher than mine.
I'm thinking I'll give the TSC blaster a go. I can always return it if my satisfaction isn't met.
Chris in Maine
Old 10-14-2012, 01:38 PM
22-W's Avatar
I'm glad the idea is at least staying in Maine! Actually, I think mine are narrower than yours as they don't stick out past the tires very much. They had two different widths if I remember correctly. Now we have to convince Madam that since she is in Maine she needs these on her vehicle! (or her bike)
Old 10-18-2012, 11:43 PM
akabull's Avatar
Maine-iac
I think it is a must that they get installed on her bike! She'd only have to buy one though and rip it down the middle to get one for the front and back tires.
Chris in Maine
