Old 11-25-2012, 01:47 PM
read, somewhere, that those Dysons aren't the value they're cracked up to be.
There have been several discussions at work about these new fangled 'Dark Side' movie killers. All of those that were bought were gotten rid of in quick fashion with little more than a few hours use.
Old 11-25-2012, 02:04 PM
Originally Posted by madam X View Post
How pretentious are those ads, anyway?
I love it when you use big words!
You pay for that noise dampening dearly on the household units.
Yeah, both in cost and in loss of suction. That's one thing about even the cheap shop vacs--most of them do suck pretty well because they just let'em rip with no noise damping...
Originally Posted by RancherBill View Post
I really like my Ridgid...
Vacuums aren't exactly the kind of thing guys sit around over a beer and discuss so you don't hear a lot about them but the little I have heard suggests the Ridgids are pretty good. The shop vacs from Karcher look to be top of the line as well but I suspect they're pretty pricey...
Old 11-25-2012, 02:25 PM
monte55 monte55 is offline
I ran the vac for 15 minutes and sounds fine. I have put it all back together and it's happy now waiting for its next job. Btw..all the electrical data, model number, etc is molded into the plastic motor cover part. I am so sick of the crappy paper and if you're lucky, foil, info stickers they put on everything now. Hell, wash your lawn mower a few times and hope the info plate is still there.
www.nixstuff.com
Old 11-26-2012, 01:21 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
I read a pretty good review on the Fein or is it Fien brand of shop vac, a few years ago. They're supposed to be pretty quiet and work well. They are a little pricey, though.
Dave
Old 11-26-2012, 01:54 AM
Destructo_d Destructo_d is offline
Send a message via MSN to Destructo_d Send a message via Yahoo to Destructo_d
Surprised no one has mentioned a vacuum powered by your shop air supply:
http://www.exair.com/en-US/Primary%2...ac%20Home.aspx
And I am sure there are plans out there to make something like this too
Old 11-26-2012, 07:25 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Glad to hear you saved it.
I bought a Ridgid from HD a few years back it has held up well, I use it to clean up the mill and surface grinder frequently. It has been used to suck up water, antifreeze, and other non-flammable liquids many times. I use it on my glass bead booth with a Hepa filter in it.
I have a Vacuum Material loader motor mounted on a resin drum that will be my dust collector once the shop is finished, it really sucks. I save it from a scrap drum when I work for a local plastic injection molding company.
I have to decide whether to set up two separate pipe systems or build a diverter valve to switch between dry or wet system.
Since I am going to put the system on my surface grinder, bench grinder, and 12" disc sander I need to have a liquid filter to prevent a spark from traveling to the drum. I would prefer not to have the moist air setting in the drum.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 11-26-2012, 07:32 AM
Why do vacuum cleaners in general and shop vacs in particular have to be so noisy?
2 things going on here.....
The fan (or I should say the blower wheel) the blades come around the
openings in the housing all at the same spacing.
I can (and have) laid out these things to have un-even spacing
of the blades, but still maintain balance.
That would take care of the fan noise, but the second part
of the noise is from the brushes riding on the commutator.
Which I can't make the spacing un-even.
I suggest the vacuum manufactures go with a small 3-phase
motor running on a 1-to-3 phase invertor, and over clock
it past 60 hz. for the high speed.
But that would probably cost too much.....
