Old 12-06-2015, 04:13 PM
greywynd greywynd is online now
Default Laser Welding
One of the companies I'm working with is looking at laser welders for repair work on molds.
Primary use is steel, typically P20's and similar, stainless (can't remember the alloy), and also some copper/beryllium alloys (MoldMax being one of them).
I know there's guys here that have some varied experience with high end stuff, any knowledge of this process?
Since some of the molds are large (up to 90,000 pounds) they are looking at a portable type unit, http://www.or-laser.com/en/lasersystems/evo-mobile/ being one of them.
They're fairly confident that corporate will give the nod, as it will save a lot of out sourcing. Our typical shops for this are about a $3-4000 round trip ride via dedicated truck, with about 20-30 of those a year. Of course the work is also pricey, often 20-30K.
Even if we can keep 10 of these jobs in the shop a year, it should payback the $110,000 pricetag within a year or so.
Sent from my iPhone using SFT
Old 12-07-2015, 01:54 AM
The next question will you be able to keep a qualified operator on it ,or joe from the crashit department.
Old 12-07-2015, 07:14 AM
weldor2005's Avatar
Perpetuus Discipulus de Vita
It's been a while since I've operated a laser, but I wonder about the application here. Most lasers are intended for precision and ran off a CNC system, which makes me wonder if you are trying to use a scalpel where clearly a Bowie is called for?
I did some tool and die welding, and it seemed that when repairing molds or dies, it was a heavier process to add the metal and then machine it to tolerances. Just curious I guess, I either saved you a lot of money in a purchase that wont work, or am completely off in the industry now a days. Either way would be neat to see the end game.
David
My YouTube Channel
Old 12-07-2015, 01:19 PM
In this case it's often small amounts of weld required to fix corners of parting lines, but they struggle getting a decent weld without heatshrink, blowing corners away and the like.
Generally after welding it's all hand rework/spotting. Using the laser should minimize the amount of material needing removed, speeding up the process. Also should eliminate a lot of rewelding due to a spot being missed and a few other common issues.
Old 12-08-2015, 12:02 PM
weldor2005's Avatar
Yes, but I see that most if not all laser welding applications are autogenous and don't add filler metal. I find you have a different system in mind for this?
David
My YouTube Channel
Old 12-08-2015, 12:35 PM
System we're looking at can go down to .005" filler rod, commonly uses a .015" IIRC.
Any laser stuff I've seen for toolwork is all buildup work with filler.
Old 08-23-2017, 06:06 PM
Finally got a chance to try out a system in person for this. Just doing the basics for now, running passes learning how to build up a damaged surface or edge. Filler metal is generally .015 or .020 in diameter. Grabbed a couple pics.
Time for a new signature line!!
ID:	140618   Click image for larger version
Old 08-24-2017, 12:33 AM
Mostly punch press or is it a cast or plastics plant ?
Old 08-24-2017, 12:51 AM
This is in a plastics molding plant, mainly large automotive parts. Molds that can weigh 100,000 pounds, so as many repairs as possible are done on site.
Old 08-24-2017, 06:50 AM
weldor2005's Avatar
Funny, I look back at the date you first posted this, and thought to myself, why did I comment that? I have since seen a lot of this type of welding being done online and Instagram, but no experience myself. I wish you luck in this endeavor and would like to stay informed on it.
David
My YouTube Channel
