Old 08-24-2017, 07:07 AM
It's not a common system even in this day and age. I'd call this a 'semi-automatic' power source, so it has servo motors in three axis controlled by a joystick. This moves the laser pulse how the operator wants.
The filler rod is manually held, by hand. You really don't need to feed it, as the laser travels it basically uses rod as it goes. Just hold the rod, no feeding required.
Time for a new signature line!!
Old 08-24-2017, 11:46 PM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
What kind of eye/face protection do you use on something like that? Too tired right now to google the process, and prefer to get the info first hand when I can.
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 08-25-2017, 12:22 AM
The operator is looking through a microscope, and it is filtered/shielded so no additional protection required.
If someone is near/in the welding area, there are basically safety glasses that are specific filters for the exact wavelength of light. This particular laser has a focal length of just .012", closer or farther and the beam spreads out, losing power.
We then have a laser specific enclosure around the area, with an electronic interlock on the access door. If someone opens it while we are welding it triggers the e-stop on the welder shutting it down.
Really once you know the hazards, similar to other welding, it's overkill, but due to the average worker being in the area, it was better to overdo it.
