Old 09-10-2017, 07:20 PM
Default Filling Oxygen cylinders
With Cutter talking about Oxygen Concentrators I decided to search Craigslist under "Oxygen" and came across this.
I have nothing to do with the ad or know anything about it.
I guess this guy is filling welding cylinders.
Looks like there is a rear outlet port on the Concentrator that plugs into the upper refill pump. (wonder if there is a Duty cycle on the refill pump I would assume it would run all day filling a 130 cu-ft cylinder)
with some time I would guess the setup could be had for about $1000 or less.
From the listing ( he wants $2200).
"Don't think I can go any lower than this since the compressor alone is 2500 usually
I've been feeling my own oxygen tanks and no longer need the rig set up to fill just about any size oxygen container the adapter hose goes from the rig to a standard welding bottle but can be easily modified to fill just about anything with 2,000 lb worth of oxygen
The setup includes oxygen concentrator and oxygen compressor which compresses up to 2,000 pounds oxygen bottle and hose adapter that goes to just about any welding tank
As you can see in the picture they're both Invacare unaltered items I'll be willing to demonstrate but it's pretty much cut and dry hook it up turn ball valves on switch the machines on and they truck along until you have 2,000 lb of O2
For some reason this post gets flagged no explanation no nothing don't let internet bullying ruin Craigslist believe items like this that cost big business money they're trying to not let people know about "
Name:	a 00I0I_dcObHfjGeYF_600x450.jpg
ID:	140968   Click image for larger version
Name:	B 00L0L_hBC4Od8nTe2_600x450.jpg
ID:	140969   Click image for larger version
Name:	C 00m0m_QU3PmtX3MS_600x450.jpg
ID:	140970   Click image for larger version
Name:	D 00202_4KEsWgPpL8m_600x450.jpg
ID:	140971   Click image for larger version
Name:	E 00u0u_9BD09jILqEK_600x450.jpg
Old 09-10-2017, 08:09 PM
Ya gotta love it when a guy beats the system.
Old 09-10-2017, 09:25 PM
I'm not so sure that he has. I believe that's a really slow process.
I would need a 2nd concentrator to use while that one filled the tanks.
When you consider the initial investment and the running time to fill even a small tank it would be hard to justify.
If a person in strong need of filled tanks living in a remote area had access to electricity & no other source of O2 then it would probably be worth it.
I want to go home!
Old 09-10-2017, 09:31 PM
MAC702's Avatar
MAC702 MAC702 is offline
set phasers to .50 caliber
The system is like a wife. You go to prison if you beat it.
Old 09-10-2017, 09:45 PM
$600 or best offer from Denver. concentrator with pump.
https://denver.craigslist.org/hab/d/...259691915.html
As some of our members have stated they have to rent cylinders you can not buy them and get them refilled.
So what is the rental cost in savings?
Old 09-10-2017, 10:12 PM
Can you figure out how long it would take to fill a 164 liter cylinder?
Then we'd need an honest estimate of the useful life of that little compressor, working up to 2200 psi.
I want to go home!
Old 09-10-2017, 10:49 PM
When you consider the initial investment and the running time to fill even a small tank it would be hard to justify...
Yeah, I agree. Those things are complex, slow and sensitive. If they were so good everybody would have one. I'll stick with my rental bottles and a reliable, cost-effective source of gas...
Old 09-12-2017, 01:47 AM
I wounder if Medicare paid for it, on the other hand maybe his Insurance paid.
Old 09-12-2017, 03:10 AM
looks like 2L/min to fill and 3L/min to the patient. I would guess 82 minutes.
1) fill time
2) cylinder size
3) 5 stage pump
4) belt drive (looks like a weak point plastic pulley)
The compressor just my be the thing for LW's Air Guns.
I e-mailed the person and asked how long did it take to fill a welding cylinder here is his reply.
"The tank I have it comes up to my armpit I usually run it at night since I'm not in a hurry I figure about 16 to 20 hours to fill it"
Name:	Cylinder fill time.jpg
ID:	140989   Click image for larger version
ID:	140990   Click image for larger version
ID:	140991   Click image for larger version
Name:	belt drive.jpg
Old 09-13-2017, 09:28 AM
Gwiz, the time to fill small cylinders appears to range from roughly 1 to 2 hours; that is less time than I would have guessed.
If I had to buy the equipment to do it I probably would have zero interest in it so long as there was a reasonable alternative. Again, it is not clear to me whether the concentrator can pump enough oxygen to allow it to be used as a suppy to the patient at the same time it is filling cylinders but I doubt it.
That would mean that someone like me would need two concentrators plus the compressor unit, putting the total cost at about $3000 plus whatever investment one had in cylinders.
If there was no alternative then it could be a life saver but it takes just about as long to refill a tank as that tank can supply my use of it. This becomes something of a Catch 22.
My cost to get small cylinders filled at an oxygen supply house is ten bucks.
When a small cylinder needs to be tested & re-certified there is an additional $16 charge.
I think these are reasonable costs but only for having 2 or 3 backup cylinders in reserve for possible emergencies such as power failure, concentrator breakdown, etc.
Another real problem is the cost of the cylinders themselves if you have to pay retail for them. By the way, I was also told that old steel cylinders are pretty much useless because the valves generally seize to the threads & cannot be removed for testing by the supply house/testing facility.
I want to go home!
