Old 10-05-2010, 09:21 PM
Vernon's Avatar
Vernon Vernon is offline
Default Welding Cart
I made a cart for that same machine I will try to find the pictures with the machine on the cart and painted blue. But heres some building pictures.
Vernon
ID:	66565   Click image for larger version
ID:	66566   Click image for larger version
ID:	66567   Click image for larger version
Due to the lack of effort today Tomorrow has been canceled...................
Old 10-06-2010, 07:40 AM
~Stick/MIG~'s Avatar
~Stick/MIG~ ~Stick/MIG~ is offline
Thumbs up
Nice job on the cart!
Originally Posted by Hollywood View Post
Here is another project from last week. Had this mobile car lift that was taking up space for the past year, so I converted it to an adjustable height welding table with a sheet of 3/8 steel.
That's a very nice welding table! ... I like it!
Thanks for sharing your projects!
Vernon
Very nice Vernon!
It looks very thought out!
I'm looking forward to seeing pictures of it finished!
I'd like to build a cart to hold both my MIG & Stick welder.... Too many projects on my list right now!
Thanks for sharing!
Old 10-06-2010, 06:31 PM
Vernon's Avatar
Default Miller Welding cart
Hey ~Stick/Mig~,
Here are the pictures of the cart I made for the Miller Syncrowave 250. With paint
Vernon
ID:	66582   Click image for larger version
Old 10-06-2010, 07:44 PM
dodgewade dodgewade is offline
Here is another project from last week. Had this mobile car lift that was taking up space for the past year, so I converted it to an adjustable height welding table with a sheet of 3/8 steel.[/QUOTE]
Hollywood, Would you give up some more information on the lift table? I like the looks of it and really need one.
How long is it?
What did you use for the lift part?
Did you use bushing on the pivot points?
Are the wheels solid?
PM me if you'd like,
Thanks,
Have A Big Time.
Wade
Old 10-07-2010, 05:17 PM
Hollywood Hollywood is offline
Send a message via ICQ to Hollywood Send a message via AIM to Hollywood Send a message via Yahoo to Hollywood
Wade, your giving me to much credit on the welding table. It was an easy modification of a car lift similar to this:
http://www.revolutionlift.com/RMR6-6...Lift-P4C9.aspx
What I did was remove the lift arms from the base of the lift as well grind off the couple of "stops" that were welded to it to get a flat base. I had the distributor cut the metal to size before we picked it up. I added a quick release to the hydraulic hose so the pump can be wheeled completely away from the table. The plus to that is that when I get my JD2 bender I can run it off the same electric over hydraulic pump. The lift itself has a pair of hard steel rollers on one end, and the pump cart is used as a lever to pry up the other end. You "steer" it with the pump cart...not an easy task, because the thing is pretty heavy.
Old 10-07-2010, 06:44 PM
Hey ~Stick/Mig~,
Vernon
Very nice!... You did a great job!
That's also a nice Miller!
Thanks for sharing!
Old 10-07-2010, 07:22 PM
It looks good regardless. Wish I could find something similar to use. I bought a motorcycle/atv/utv scissor lift table last year, but need something like you got there to build a buggy on. Been looking for a old scissor lift to use, no luck yet.
Could I talk you into getting some measurements and material sizes?
Thanks,
Wade
Have A Big Time!
Tags
cart, syncrowave, tig
