Old 04-29-2011, 11:01 PM
hertzmille1 hertzmille1 is offline
Lookin good!
Old 05-04-2011, 12:15 PM
Ram48's Avatar
Ram48 Ram48 is offline
Default Its done and works great
Here are pictures of my completed cooler. I was shooting for $225 when completed but decided to upgrade a few fittings and use better hose so the final cost was just under $250. which includes the parts needed to convert the Wp-20 torch. It works real well and my new torch I practiced quite a bit and the torch was always at room temp and the water in the tank was cool.
I will build a case for it soon but have friend and his 1962 Mini cooper arriving tomorrow so I will be playing with that for a while doing the aluminum interior and a few other things I am sure.
Name:	tig cooler 3 001.jpg
ID:	75973   Click image for larger version
Name:	tig cooler 3 002.jpg
ID:	75974   Click image for larger version
Name:	tig cooler 3 003.jpg
ID:	75975   Click image for larger version
Name:	tig cooler 3 004.jpg
ID:	75976   Click image for larger version
Name:	tig cooler 3 005.jpg
Old 05-04-2011, 12:23 PM
Which way does the fan turn, Ray - does it suck or does it blow air through the cooler?
I want to go home!
Old 05-04-2011, 12:33 PM
Ram48's Avatar
It pulls air thru the cooler and and over the motor it will take and hold a sheet of paper from my hand held a couple of inches away
Old 05-04-2011, 11:32 PM
Paychk's Avatar
Paychk Paychk is offline
Project Phoenix
Nice!
What is the reservoir from?
Ory-gun Boy!
Old 05-05-2011, 06:46 AM
Ram48's Avatar
Originally Posted by Paychk View Post
Nice!
The reservoir is a 7 qt go kart gas tank that I found on line I think it was $25
Tags
cooler, tig, torch cooler
