Old 07-19-2005, 01:41 AM
widetrackman widetrackman is offline
Default Drill press arbor/chuck ?
I have a Craftsman 17" drill press that has not had a lot of use , but noticed that the chuck has some slack (when tight) between the arbor seat and the chuck its self. The chuck is only marked RJ3 16L (no name) ? chicom. Was thinking about changing to a Jacops super chuck but dont know the following; 1( the taper in the quill, 2( is the arbor removable from the chuck, 3( really dont know how to do this. Any help from you guys would be great. Thanks.
Old 07-19-2005, 01:57 AM
Widetrack,
I suspect you could help a whole bunch by posting some pictures of the quill/chuck/arbor.
I want to go home!
Old 07-19-2005, 02:27 AM
90% chance it is a JT3 taper (JT=Jacobs taper); 9.99% it is a JT33 0.01% it is something else.
All chucks are removable, typically you would use a tapered dog to remove them a U shaped wedge where the top or points of the U are the thin edge of the wedge and the bottom of the U is the fat part of the wedge.
Old 07-19-2005, 06:27 AM
Arbo's Avatar
Arbo Arbo is offline
Your spindle will be one of two things. First, try extending the spindle of the drill press all the way out. If the spindle has a notch cut through it, it has a morse taper internal taper. In this case, insert a drift into that notch and give it a light whack with a mallet. Be ready to catch the chuck and morse arbor so it doesnt fall on your toes. Second, the spindle may have a male jacobs taper machined directly on the end. In this case, you must drive a wedge between the top of the chuck, and the drill press quill. They make chuck removal wedges for thsi purpose. They are available from Grainger, MSC, etc. They are relatively inexpensive. Im with Shade, guessing that it will be either a Jacobs 3 or 33 taper. If you have slop between the spindle and the chuck, that tells me that there is a good chance that the taper may be b1tched up. If the female taper on the chuck is bad, replace the whole chuck. If it is the male taper on the end of the spindle, good luck is all I can say. Once you get it apart, check back here for some reassembly tips.
Arbo and Thor (The Junkyard Dog)
The next loud noise you hear is me!
Old 07-19-2005, 11:07 AM
Franz Franz is offline
Banned
I work my fingers off here, and you guys don't do your homework.
All taper sizes are available on ShopFloorTalk unlike the intelectual web site
http://shopfloortalk.com/forums/showthread.php?t=439
Old 07-19-2005, 11:13 AM
But we do so appreciate your tenacity.
I want to go home!
Old 07-19-2005, 02:49 PM
bgott bgott is offline
Trailers for sale or rent
He said Craftsman, guys. Open up the chuck and look up inside. There might be a screw in the chuck to lock it in place. Like the screw they use to lock the threaded chucks on a hand drill.
Old 07-19-2005, 07:43 PM
7018's Avatar
7018 7018 is offline
Mine is a Craftsman and it has a removable chuck!!!!!!
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 07-19-2005, 10:44 PM
Don't get me wrong, Craftsman has a lot of good tools. I get their Tool Club flyers and buy stuff out of them occationally. However, Sears doesn't build the stuff, they contract it out, and they change models on a regular basis. I have seen some really cheesy stuff wearing the Craftsman name. They also have regular old Craftsman, Craftsman Commercial and Craftsman Industrial. If he has a regular Craftsman I'll bet it stands a good chance of having a different chuck arrangement than a Industrial. And that might change the next catalog cycle.
Old 07-19-2005, 11:10 PM
Originally Posted by cutter
Widetrack,
Cutter, Ive got a good digital camera and can get the pic's on my computer, but beyond that, well ??? not much of a computer guy, just surf the net. If there's a simple way maybe the wife could set me up, she's a little smarter at computers
