Old 12-10-2017, 04:16 PM
digr digr is online now
I forgot to put O rings in the end caps.
Old 12-10-2017, 05:31 PM
I used to use the coats center post styles, we had one at the garage,
then my weld shop neighbors had one.
So I Bought one for myself.
I then bought a "May Tire-A-Matic" and like it much better.
You need to make the spindle rotate with a motor, and a little disc/wheel
for the bead breaking. Even thought mine has a double ended air cylinder
to bring in the bead breaking wheels, you could use a long lever
for the same purpose.
I posted the manual for it here on SFT.
Old 12-10-2017, 09:47 PM
Samcord Samcord is offline
Looks like you could get by with single action, with a spring for the return.
Old 12-10-2017, 09:59 PM
Oh yeah! You still need to vent the pressure for the return. Doh!
Old 12-10-2017, 10:03 PM
Maybe this one?Click image for larger version
Old 12-10-2017, 10:24 PM
Maybe this one?Attachment 142514
Looks like that valve would work. Saved the link. Thanks.
Old 12-10-2017, 10:31 PM
The Tire A Matic is similar to my Bishman. Neither will do small tires.
Old 12-12-2017, 03:32 PM
I understand that completely.
The point I was trying to make (and you missed) was for you to MAKE YOUR OWN "Mini tire-a-matic".
The main point being the unique roller (or disc/wheel) bead breaker
along with the motorized center post.
Not anything at all like a normal center post style.
Old 12-12-2017, 06:41 PM
I did see that, but I wanted the air operated cylinder function. This one will be able to do large tires as well as small tires.
Old 12-13-2017, 05:12 PM
I am not having a lot of luck finding a 3' piece of 5" thin wall tubing for under $50. Anybody here got a chunk they want to sell?
