  #51
Old 12-20-2017, 03:53 AM
Rob65 Rob65 is offline
When I suggested plastic for the cylinder I was thinking of a fairly thick walled pipe with the end caps held on with tie rods.
If you can only get thin walled pipe like say domestic drain pile it would be easy enough to fabricate a steel 'container' that the plastic pipe would go inside with a bit (1/2"?) of clearance, and then fill the space around the outside of the plastic pipe with concrete to stop it expanding.
I guess it's a question of how much trouble you want to go to working with materials from the big box store for a few $ against paying out more $ for more traditional cylinder materials.
  #52
Old 12-20-2017, 10:06 AM
randydupree's Avatar
Why, Hell Yes!
Get yourself a small welding cylinder,the way they make them (saw it on TV) they may be round enough and long enough,after you cut the ends off.
  #53
Old 12-20-2017, 12:40 PM
digr digr is online now
Perfect!!! PM me and let me know the cost and how you want it sent.
Its on its way, should be there Saturday
  #54
Old 12-20-2017, 11:39 PM
The PVC will be schedule 80. Plenty strong for the max air pressure I would be using. Tie rods are what I plan on using. I will machine a groove so the pipe fits in tight. A O ring will be the seal at the bottom of the groove.
I have been known to lean towards spending more time than money.
I had thought of that but expect the inside of the cylinder would likely not be concentric or smooth enough. I have a scuba tank I could use, but no way I could turn it on the lathe to get it smooth enough. I would need a 2' long boring bar.
Trading is a good thing!!!
  #55
Old 12-22-2017, 11:19 PM
Found a cultivator disc. It is 22 1/2" diameter. Plenty large enough. Parts collection is going pretty well. Only major item is the 5" schedule 80 PVC pipe. I know a well driller that may have some remnants laying around.
I will start a new fabrication thread once I get all the parts collected.
  #56
Old 12-24-2017, 04:29 PM
I was wrong. It arrived Saturday. Looks like just what I needed. I see there are no tapped thread holes for mounting. How do you suggest I mount it? Make a cradle of some sort and bolt the cradle to the machine frame?
I see your care package left St. Paul this afternoon.
  #57
Old 12-24-2017, 06:38 PM
Suppose I could replace two of the allen head screws with 1/4" longer screws and mount it to a piece of angle iron?
