Old 12-20-2017, 10:37 PM
OldRedFord's Avatar
Kibble King
Default Shop electrical
I'm looking at going with a 400 amp single phase service for my shop/living area. Also thinking that in the future if I build a actual house I can pull power from this service.
That said..what amperage feeder will I need to run a 40 hp rotary phase converter? I presently have one 20 hp load which is a air compressor.
Tim
Old 12-20-2017, 10:56 PM
Wow why do we need a 20HP compressor
Old 12-21-2017, 09:59 AM
Some numbers: http://www.northamericaphaseconverte...iAAEgKJFvD_BwE
Old 12-21-2017, 06:30 PM
OldRedFord's Avatar
Kibble King
Never want for more CFM.... hopefully.
Originally Posted by USMCPOP View Post
Hmm... according to that link anywhere from 60-200 amps???
Tim
Old 12-21-2017, 09:24 PM
Just read the data plate on the 40hp idler motor.
Everything else in a rotary converter draws a negligible load.
However, you shouldn't actually need a 40hp converter to drive a 20 hp motor.
I think all of your big plans to overpower your proposed shop is going to bite you on the ass if you manage to pull it off. The cost of operating equipment 2 or 3 times as large and powerful as you actually need is going to cost more to operate than you can make it produce, and it's likely to be too cumbersome to do the kinds of tasks you're most likely to be doing.
I want to go home!
Old 12-21-2017, 10:17 PM
Well, one thing Tim is not going to do wrong like a lot of people, is he is going big right up front. I know when I ran power to my shop, I wish I had put in a little bigger wire for what I would like to run now twenty years later. It would have been cheaper back then to do it.
Old 12-22-2017, 12:19 AM
Riverr1 Riverr1 is offline
Can't help with your question but I'm envious of your dilemma. Zoning here limits anything not farming or commercial to 200 amps per drop\meter. Where access to 400 amps is available, 3 phase is also available.
Old 12-22-2017, 12:06 PM
What is running at the street, ORF? I would rather have 200A three-phase than 400A single-phase. Both would be better--if you're going big, may as well go full boat! The this would be for the option of CNC machining or turning centers not that I'll ever own one.
THIS ^^^^ The money you "save" by picking up old iron will be offset by money spent on moving it, fixing it, and/or powering it.
Old 12-22-2017, 03:40 PM
OldRedFord's Avatar
Kibble King
I'm zoned agriculture or A1. There is three phase running about 1000' away from my property.
I'm looking at putting together a price and parts list to do a 400 amp single phase service and do the same for a 200 amp three phase service. In both cases I'll clear the right of way and lay cable and conduit to the pole.
Far as old machines.... condition is everything. If I saw a Monarch lathe in decent shape and a Grizzly metal lathe for sale at $2000 each...I'd grab the Monarch.
Far as moving things...I have access to a 30 ton lowboy and a 20 some odd foot roll back wrecker, a Pettibone PB30 crane and a assortment of rigging supplies.
Tim
Old 12-22-2017, 04:07 PM
randydupree's Avatar
randydupree randydupree is online now
Why, Hell Yes!
so,just to make this clear in my mind,1000' away from your property line is a power line with 3 phase power.
That power line right of way does not touch your property line,right?
So you think your going to bury 1000 feet of conduit and cable across somebody else property to get to the power line RoW.
Is that right?
At my old place in Fl. 3 phase power was about 1000' from my place,to run it to my shop was an estimated $30,000,in 1990.
Taller power pole,wider easements,3 transformers etc.
I bought a 3 phase generator and for all the hours of use it worked out real well.
And i was working in the shop everyday,7 days per week.
Of course i did not have a 20hp compressor,just a dinky 5hp Champion.
My lathe,just a dinky 12x60 South bend,single phase
My mill,its bigger than the average Bridgeport,and its 5hp,3 phase,
Welders are all single phase
I had a 3 phase Burgmaster turret drill and mill that got most of the use,drilling and tapping plastic parts,actually i had 2 of those Burgmasters,a small version and a big version.
We made one part on each machine,we could run both machines at the same time,one person feeding parts into both machines.
Tim,Go Big or Go Home!!
