Old 12-21-2017, 09:43 PM
Default Phase Converter questions
Seems I'm going to be needing a phase converter sometime in the future. So I'm on the lookout for a suitable idler motor.
In this part of the country, a lot of the three phase equipment is 575 volt. Am I correct in my thinking that I need to find a 208/240v motor?
I think I have a 5hp motor, have to check it out and see though. I'd love to have a 7.5 or maybe a 10, that's likely as large as I'd ever need. If the 5 is usable, I'd likely wire the controls and such to handle a heavier motor if I can upsize in the future.
Old 12-22-2017, 12:15 AM
You need one for whatever your incoming voltage is.
Old 12-22-2017, 12:16 AM
Also remember that you can't run a 10 horse motor from a 10 horse converter.
Old 12-22-2017, 01:52 AM
Norcal Norcal is offline
Can't run 600V equipment on 240V without a transformer, since your in Canada a suitable 600V X 240V X-former should be more common.
Old 12-22-2017, 08:17 AM
Right now the biggest motor I'll have to run is the 2hp on the mill. Fortunately it's 220v, so no transformer required.
The grinder spindle motor is 575v, so I have to decide what I'm going to do, but have started watching for a 220 to 575 step up transformer. They aren't a common item though, and people seem to hang onto them if they know what they have. I had a big one several years ago, bigger than what I figured I'd ever need, and gave it to my brother to use with his phase converter.
I hope to get a quick moment to check the voltage on the 5hp motor I have today before I start my travels.
Old 01-14-2018, 08:37 PM
So of course the motor I have is 575V, not a candidate to build a phase converter.
I did find a 5hp rotary phase converter, as part of a package with a 208-575 transformer. No pics as of yet, asking price is $900 Can. Seems a bit high to me, but guess it depends what all comes with it.
Old 01-14-2018, 09:03 PM
You can do it either way, 240v x 600v single phase xformer, then
onto the RPC motor. However, finding a Steevco voltage sensing
relay will be a bit tougher, as well as 600v rated caps.
Or, like I do (and most do) 240v RPC motor, then thru a 240v x 600v volt
3 phase xformer.
Old 01-14-2018, 10:36 PM
Seems all I can find are 575/600 volt motors, which then makes the rpc parts tougher/more expensive to source.
I know some basic electrical, enough that I can likely make it work, but have zero inventory to start from scratch. Guess I’m more wondering if the converter and transformer package is a reasonable deal at $900 Can. (About 6-700US).
I’ve asked for pictures of the unit and am hoping to get something tomorrow.
Old 01-14-2018, 11:29 PM
Have you looked for a replacement motor for the grinder? What frame and HPis it?
Old 01-15-2018, 12:18 AM
how many amps do you need, Grey? should be 2.
I may have what you need.
Herodotus
