Old 12-31-2017, 11:31 AM
Question Limit Switch ??
I bought a couple Limit Switches thinking ill use them on my pedal actuated spot welder modification....
But was not thinking on how they operate as it cuts power but not sure
if the switch cuts power when actuated can it be reversed to produce power when actuated.
I have a momentary switch the spot welder came with but don't think it will hold up being operated mechanically
any ideas from the experienced ??
ID:	142792Click image for larger version
ID:	142793Click image for larger version
ID:	142794Click image for larger version
ID:	142795Click image for larger version
..Randall.......Peace!
do nothing." -Edmund Burke-
Old 12-31-2017, 11:50 AM
When you take the cover off there should be NO or NC marked inside.
Old 12-31-2017, 12:41 PM
Your first pic shows what Digr's talking about - it's marked right on the cover. NO (Normally Open) should CLOSE when actuated. Commonly a limit switch will OPEN when actuated, to remove power. Moving connections to the OTHER pair of terminals will turn power ON when you activate the switch... Steve
Old 12-31-2017, 12:48 PM
Scotts Scotts is offline
To complete the circuit when you activate the switch you want to use terminals 3&4
There are 3 screws that hold the cover on pull off cover and there are the four screws to connect wires to.
You will only use two screws.
Old 12-31-2017, 03:00 PM
You might want to know how much current the switch will be interupting to be sure that it is operating within it's range. If the current is too high you will need to add a suitable magnetic contactor to handle the load current.
Old 12-31-2017, 04:24 PM
See who made the Actual SWITCH inside. I'd almost bet it's either Microswitch Corp or Cherry . Get the number off it and do a search to get the actual current switching rating. I've used hundreds of Microswitch switches back in the old electronic ages. :-)
...lew...
Old 12-31-2017, 04:30 PM
The switch says 5a 250v AC & 0.4a 115v DC
I Am using 230V power on a 230v HF Spot welder If that helps..
i believe it is only 25 amp when it makes the spot weld ill have to go back and look at the manual.
If its not a safe switch to use for my intended purpose no biggie please let me know. Then ill look around to find momentary switch that is in the configuration or design as the limit switch that can handle it.
Old 12-31-2017, 07:47 PM
I think Terry will be right. You will have a magnetic contractor to make that switch work.
Old 12-31-2017, 08:20 PM
...I think Terry will be right...
Terry is right. Always.............at least that's what he tells me.
Most of the limit switches I've seen are relatively low amperage--meant to work in secondary control circuits...
Old 12-31-2017, 08:43 PM
Terry is right. Always.............at least that's what he tells me. .
No that's Gerry Or is it Glenn
