JR Welding Tools
Old 03-29-2005, 11:25 AM
Franz Franz is offline
Banned
AND, when Cutter gets the Wilton open, he can go to this site and learn how to make new jaws for it.
http://www.frets.com/FRETSPages/Mach...iltonjaws.html
Old 03-29-2005, 11:38 AM
You know what? I've been dreading that.
I want to go home!
Old 03-29-2005, 07:58 PM
7018's Avatar
7018 7018 is offline
I wonder if he painted his thumb nail or is the nail paint is waering off??????????
This post brought to you by the bringer of chaos, doom, change, and technology... Asker of questions, challenger of assumptions, solver of problems and share-er of ideas
Old 03-29-2005, 09:20 PM
Banned
Not real sure what the deal on the thumbnail is, but if you back the site up to his main page, the guy is a guitar maker, and repairer of stringed instruments. For people who can tolerate wood, he has a lot of great information.
Old 03-29-2005, 10:12 PM
Jeff's Avatar
Jeff Jeff is offline
Big Iron
Question
Cutter,
You have probably already done this, but did you try bolting it down, applying pressure to jaw, and heating the dog s**t out of the barrel?
Jeff
Old 03-29-2005, 10:38 PM
Originally Posted by Jeff
Cutter,
Jeff
Did you make it to page 15?
http://www.cutterod.com/vise_saga_15.htm
I want to go home!
Old 03-29-2005, 11:54 PM
Don_S Don_S is offline
Cutter,
If I remember correctly the vise has a hole clear through the middle so this probably wouldn't work unless you could seal the center. I had a person tell me the best way he found to unstick rusted in cast iron pistons in an old tractor was to fill the cylinders with diesel and light it up. This is on an old JD two cylinder block removed from the tractor and set up on end. The burning diesel at the top of the pool heats things up while the diesel on the bottom of the pool is tenaciously trying to work it's way between the piston and block.
Don
Old 03-30-2005, 12:36 AM
river1 river1 is offline
Originally Posted by cutter
To tell the truth River, I had read about using molasses last year but I just didn't want to go buy 5 gallons of it & then have to clean up that mess too. As far as surface rust goes, I just about had that whipped & I couldn't bring myself to believe molasses would penetrate the close tolerances involved inside the old vise.
i don't know about the penetration part but to clean up the mess just pour it in your garden works great as fertilizer.
later jim
Old 03-30-2005, 12:38 AM
Don
That is an interesting idea, Don. But of course you're right, there is a 2 inch hole (app.) plumb through her to the front jaw then it closes down to about 1 1/8th in. The 3 collar screws are tapped all the way though into that cavity as well.
But hmmmmmmmmmmmmmmmmmmmmmm . . . . . . .
I want to go home!
Old 03-30-2005, 09:26 AM
EngCan's Avatar
EngCan EngCan is offline
Hi Cutter just read the vise (vice) saga, got to admire your perseverance.
Don't know if this is any help but......
I regularly clean rust, burnt on oil, other crud, by putting a 75% Glycol/25% water mix (antifreeze) in a crock pot.
Put the offending bits in the pot and set heat to full for 2 hours, turn down to low heat and leave for loooong time (week).
All bits come out clean. Siezed up items come unsiezed (is that a word).
Used this method on a cylinder (cast iron) and stuck piston. They came apart easy. The piston rigs had rusted to the cylinder bore.
As Franz is the expert on all things divine and chemical maybe he could shed more light on the validity of this process.
Regards Frank
I wander'd lonely as a cloud....
