JR Welding Tools
  #61
Old 10-05-2017, 10:00 AM
Originally Posted by Norm W View Post
There is a restricter in the return line to maintain the pressure.
IIRC it's a "normal" hardware store looking elbow, coming off the head
(in one of the holes leading to those drilled/cored galley's for fuel pressure & return)
But is has a small hole drilled in it.
  #62
Old 10-05-2017, 10:26 AM
"this old generator probably has a Silverstat voltage regulator for the generator
field"
One of Ron's pictures shows Woodard control gear.
Again one of ron's pictures shows that this is a two valve head. AFAIK these all had external fuel rails but the restrictor is there.
40 PSI on the injector rail and they will run if all else is good. Remember those valves are exhaust valves intake is through ports in the side of the cylinder sleeves.
