JR Welding Tools
Old 08-02-2017, 05:33 PM
When you said bandsaw steel I was assuming "sawmill bandsaw" which are commonly L6. I didn't think it had any nickel, but I just looked it up and it is pretty close to 15n20 in composition.
Have you ever tried etching in ferric chloride? That seems to be a popular etch for damascus, I wonder if it reacts to the nickel differently?
Probably the largest difference with any nickel or finished damascus is the level of polish.. I stopped at 180 grit.. While you can't see it in the pictures it actually reflecs light of the nickle part.. If you enlarge the vinegar pictures you can see it even more clearly..
The nickle blades have a lot of flex cycles while maintaining strength..
I have several different sizes as i can get them from my metal supplier who just throws the bands away once they are used up..
I just talked with an engineer friend who makes bandsaw sharpening equipment for Simmons and he said at some point we can go over and grab some of the scrap which are like 20ft sections that get fed into the machine before the teeth are cut and it just goes to scrap.. Some of it is as wide as 3"X 0.062..
_________________
Jennifer
My google+ page
DoALL 36"
Old 08-20-2017, 09:46 AM
Sorry it's been awhile, ferric chloride I believe has become more popular because of the ease in getting it and it's been promoted or the information has been networked so much..
A slower acid will show more as to variation in the overall Damascus bundle , because nickle is acid resistant all the other layers can be chewed out in a heart beat.. that's what happened when I went from the 25% vinegar to the 34% hydrochloric.. the hydro ate all the vintage high carbon wagon tire where the vinegar left it just a darker more robust looking pattern... the stronger acid basically washed out the full contrast and left the nickle intact. .
Sent from my SM-N910C using ShopFloorTalk mobile app
_________________
Jennifer
My google+ page
DoALL 36"
Old 08-22-2017, 05:28 PM
Today I made the guard out of some wrought iron and it was both inset (punched for ricasso area) and then punched and drifted, then cleaned up with a cape chisel to get the blade to inset properly..
Tomorrow I will make a scabbard chisel the correct width so I can finish the inlay of the handle.. I plan also on making some copper hardware and a wrought iron butt cap..
I would have prefered a darker wood but the copper should help with color..
ID:	140603   Click image for larger version
ID:	140604   Click image for larger version
ID:	140605   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
Old 08-22-2017, 07:34 PM
Ask them when they are going to make some 1 1/2" wide wood blades for the
portable bandsaw mills, but with teeth on both sides.
I have a design in my head to use the double sided blade, but can't find it
that small.
Old 08-22-2017, 07:43 PM
that small.
Well that sounds interesting?? Double sided blades sharpened on both sides? Cutting in both directions?
Sadly I won't have say on anything there.. I"ll be lucky enough to just get a few pieces of scrap..
_________________
Jennifer
My google+ page
DoALL 36"
Old 08-22-2017, 08:10 PM
Yes, on the big ones like 14" wide and 50' long. They cut on the forward
as well as the return stroke.
Smallest I can find is 6" wide. Just ask them please if one is available
or "in the pipeline".
If I can build a portable bandsaw rig using the above mentioned 1 1/2" wide
blades, it would be a game changer.
Old 08-22-2017, 09:00 PM
My engineer friend makes the sharpening machines for them so maybe he can find out.. I'll post back when I get an answer..
_________________
Jennifer
My google+ page
DoALL 36"
Old 08-23-2017, 04:58 AM
AJinNZ's Avatar
AJinNZ AJinNZ is offline
I like the steel and the 3rd pic from your last post shows an interesting etc/pattern.
I see what you mean about the iron getting eaten away but I think the effect is pretty cool.
Looking forward to seeing the completed knife.
Everything depends on how you look at it.
Doug Wood
Approach stressful situations as though you were a dog......
If you can't eat it or hump it, piss on it and walk away.
Old 08-23-2017, 03:37 PM
Most competent work Jen. Nice form and finishing.
I've always been a fan of using bits of brass and even copper when putting knives together as it jumps out at the eye on the finished product.
Over the years of doing a bit of traveling, I always made a point of visiting any type of museum found to have antique knives etc made with minimum flare. Only those of being a functional over beauty look were of interest to me and they are what I captured in picture.
I prefer the functional look over slick 10 to one, but that may just be me.
Old 08-23-2017, 05:58 PM
Thanks AJ Looking forwards to getting it done also..
Its funny you mention function vs flair. Nearly all the museums like the flair vs function so finding examples of any daily used items is nearly impossible unless it's a rare example or the workmenship is crazy good.. IE flair..
Personally I like to have just enough of a "What" factor.. Or how come..
not sure if you guys noticed but there is something which on each knife is just a little different be it shape, construction, color, bolsters, tips. pins. etc, etc.. Maybe comes from my quirky thinking..
Nothing really sticks out unless you know what you are looking for..
I wasn't able to get out to the trailer to do anything today.. Was one of those non starter days.. Ok, I did package and mail out the other knife..
_________________
Jennifer
My google+ page
DoALL 36"
