Old 09-02-2017, 11:10 AM
alchemist's Avatar
Me thinks that both Alchemist & myself were thinking your working on a
"Ford ranger truck" and now I think your "ranger" might be a ATV of
some sort ?
Sorry, I was thinking of a ford.
Do you want the running lights on as long as the ignition is on or a seperate switch?
Old 09-02-2017, 11:14 AM
Samcord Samcord is offline
That one is even better. A couple of sta-con connectors and you are good to go.
Old 09-02-2017, 11:16 AM
alchemist's Avatar
You can get a universal turn signal switch to mount on the steering column
http://http://www.ebay.com/itm/New-Chrome-12V-Universal-Street-Hot-Rod-Turn-Signal-Switch-For-FORD-BUICK-GM-/271867837437?epid=2120989742&hash=item3f4c95fbfd:g :UwIAAOSwpDdVUcob&vxp=mtr
Insulated sta-cons that is.
Old 09-02-2017, 11:37 AM
Do you want the running lights on as long as the ignition is on or a separate switch?
The rears are on when the switch is on so plan on tying into that circuit for the lights. The dash headlight switch only turns on the headlights.
Old 09-02-2017, 11:39 AM
http://http://www.ebay.com/itm/New-C...VXH5lv&vxp=mtr
Can't seem to get the link to work.
Old 09-02-2017, 11:51 AM
alchemist's Avatar
try it now
http://www.ebay.com/itm/New-Chrome-1...dVUcob&vxp=mtr
Old 09-02-2017, 11:59 AM
Works now. Have to think this over and see if there is room for this switch on my Ranger.
Old 09-20-2017, 05:54 PM
Not enough room for the switch, alchemist. Got the back turn signals done today. Snaking the wires from the rear up to the front was a PITA. The frame is TS and the other wires run through it for about 5'. Had to run a hard bare wire through and tie the wires to it and pull the signal wires through. Used about 20 small zip ties to secure all the wires to the box and up in the front end. Looks pretty professional now.
Not too sure the rear signal lights are bright enough. I have two more. Think I may add them so they face straight back. The other two are kind of at an angle.
ID:	141140   Click image for larger version
Old 10-03-2017, 03:26 PM
Samcord (Mike) helped my install the other rear turn signals today. Much better visibility from the rear now.
