JR Welding Tools
Old 10-05-2017, 07:17 PM
gimpyrobb's Avatar
Default 4l80 shift kits
So I have a 6.5 diesel in my pickup. The 4l80 is on its last leg and I've got a new milsurplus one on the way. It was originally put behind the 6.5 in hmmwvs and comes with the torque converter. My question is, should I rip the new trans open to put a transgo kit in it? I've been doing some reading and think it would help longevity. Anyone have any experience?
Old 10-06-2017, 06:39 PM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
I don't have any experience with a transgo kit in a 4l80, but when the local (25 miles away) transmission shop put a new valve body in my Allison a year or two back, I asked about a Transgo JR. (2006 6 speed Ally), and the owner recommended installing one.
I have been quite satisfied with the way my trans shifts now; always disliked the way it would shift when going around a corner in town. The original valve body had a hanging valve, "fixed" under warranty, but gradually kept having problems with some shifts, such as when taking off from a stop sign at times.I had to give the engine a lot of throttle before the trans would seem to go into gear and start moving. It was not a consistent problem, but was annoying enough that I finally said piss on it and had a new valve body put in.
I was told that the transmission would also handle heavy towing better and last longer with the kit installed.
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 10-09-2017, 07:42 PM
Camaro Zach's Avatar
I have one in my truck. Shifts firm and crisp. Install was easy (although I didn't install the new springs in the pump that the kit comes with myself, had a shop do that after a later rebuild)
Lots of people have good luck installing them in junkyard 4l80e s and having them hold 6-700 hp.
Sent from my iPhone using SFT
Buggy
Old 10-11-2017, 04:46 AM
gimpyrobb's Avatar
Thanks guys. I hate to open up a new trans and work on it, but I think I will upgrade it.
