Old 10-11-2017, 07:57 AM
gimpyrobb's Avatar
Default Hydraulic press questions
So 2 years ago I got a 20 ton press. It has done most of the tasks I've asked of it, 2 it failed at. I have found a Dake 150ton tire press:
http://www.dakecorp.com/products/tir...e-press-33-587
near me for under $1k and I'm seriously thinking about it. I have no NEED for it, but the fact that its local and cheap(its at auction and right now under $500), I can't stop thinking about it. What are your thoughts?
Old 10-11-2017, 07:59 AM
gimpyrobb's Avatar
I swear I put this in the mechanical section.
Could a moderator move it please? Sorry for the trouble.
Old 10-11-2017, 08:20 AM
My first thought was. "sure, why not?", then I started reading the specs.
"ram speed 1.5 inches per minute."
That doesn't sound as universally useful as your 20 ton probably is.
Then I see that the ram return is by gravity.
Anything you put on it will be squeezed from the bottom up, not the way I think of a shop press working.
I wouldn't want the damned thing taking up space in my shop.
I want to go home!
Old 10-11-2017, 08:25 AM
Not ideal for a shop press, but it sure would be fun for squishing stuff.
Old 10-11-2017, 09:20 AM
If ya got the $ for it, go for it. You could build a ram for the top and use the existing power pac for it. Even if you only put a 60 ton cylinder on it, that press will stand up to the abuse.
Old 10-11-2017, 10:09 AM
1. There is a reason it is cheap. Not really useful in its current configuration.
2. It would make a hell of a cider press.
3. If cheap enough you could buy it modify it for a top down press. But I
... would keep your 20 tonner for most of your work an use this one for when
... you really need to fuck something up.
Story about #3 a friend and neighbor rebuilds CNC for a living, and does
spindle rebuilds for side work. He was rushing one day and pressed a part
onto a spindle backwards. Yeah, it was really bad. The right way was a press
fit the wrong way was a 0.030" friction weld fit. We found a local shop with a
750 ton horizontal press. We got the collar off but bent a 5" diameter spindle
in the process. Ira's nickname is "Spindle Bender" now... Good lesson in not
rush critical operations.
Old 10-11-2017, 01:20 PM
gimpyrobb's Avatar
I hate to pass, but I don't NEED it.
If anyone is interested:
http://www.govliquidation.com/auctio...tTo=USD#bidBox
Old 10-11-2017, 04:47 PM
gimpyrobb's Avatar
While it still went cheap, it was out of my price range (just looked, didn't watch the end).
I'd have been mad if it went for 190 the last price I saw it at.
Old 10-11-2017, 07:25 PM
Don't feel a bit bad I looked at the pictures and someone disassembled the
ram and the bore has significant rust in it. Not worth the almost $1000 it
sold for. It was a pig in a poke.
