Old 06-25-2017, 10:15 AM
King of Obsolete's Avatar
King of Obsolete King of Obsolete is offline
Published Author
Default the Bar Starter 30 years later
i had to whip up another bar starter yesterday 30 years after i made the first one. this is a bigger motor and more thought was required to build it. to prove a point i put a pipe wrench on the drive shaft of the motor then bounced my body weight on the pipe. nothing happened. used the same pipe on the bar starter and only one hand and the engine broke free.
thansk
KoO
Published Author
Name:	bar starters june 24 2017 001.jpg
ID:	139854   Click image for larger version
Name:	bar starters june 24 2017 002.jpg
ID:	139855   Click image for larger version
Name:	bar starters june 24 2017 003.jpg
ID:	139856   Click image for larger version
Name:	bar starters june 24 2017 007.jpg
King of Obsolete
Cat Train Tours
Cat Trains forever or until the snow melts
card carrying member of the Writer's Guild
Old 06-25-2017, 10:35 AM
What do you do to keep the starter gear engaged? Weld it? Wedge?
Old 06-25-2017, 11:12 AM
I like the mechanical advantage! First time I have seen that.
Old 06-25-2017, 12:08 PM
Published Author
yes the bendix is welded in the engaged position. lots of welds too.
thansk
KoO
Published Author
King of Obsolete
Cat Train Tours
Old 06-25-2017, 07:58 PM
This looks like a very good way to bust a tooth (or teeth) off a flywheel...
Old 06-25-2017, 08:27 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
If that engine would kick over and start, it would beat you to death before you could let go of the pipe.
We are all given many opportunities in life to keep our mouth shut.....we should take advantage of as many of those opportunities that we can.
Old 06-25-2017, 09:10 PM
Samcord Samcord is online now
How ya gonna get ignition with 1/4 turn of a starter motor? Seems like any compression would leak down in the time it takes to remove the starter, and install the whojamacalit. Also I don't think this is the type of thing you would need on an engine in running condition.
Old 06-25-2017, 09:19 PM
Scrapper Greg's Avatar
Guys, if Joey can get any compression out of that engine I would be greatly surprised!!!! Look close, the head is off the engine.
MAGA
Old 06-25-2017, 11:02 PM
Published Author
yes, the engine will never start because it is seized and the bar starter just breaks it free. you will never break a tooth off the flywheel or bendix because the small diameter armature will break before that will happen. in 30 years of use, i have never had a problem that is why i built it in the first place.
the grader engine is back together and a week from now when the gasket goo is dry i can try starting the engine with a real electric starter hooked to the batterys, lol.
thansk
KoO
Published Authp
King of Obsolete
Cat Train Tours
Old 06-26-2017, 08:30 AM
thansk
KoO
Published Authp
I think it's a great idea, and back when I had to break seized engines free, I sure wish I had thought of it.
I used to use a pry bar on the teeth of the flywheel, after filling the engine to the tits with diesel for a week.
It is tempting to blame others for all this, especially those in control of the system, but don’t forget that for decades you voted for people who routinely lied before elections, and told you what you wanted to hear, that you could have it all right now and to hell with the future – well, that future has now arrived. Clive Maund
Even duct tape can't fix stupid ... But it can muffle the sound.
