Old 04-29-2010, 07:07 AM
AJinNZ's Avatar
AJinNZ AJinNZ is offline
Default A folder question
Last year I bought an 8 foot or so length of scrap plate an inch thick and approx 6 to 8 inches wide.
I want to use it to make a 4 foot folder with this plate being the top and bottom parts.
Got to wondering however, and before I get caught up in buying parts and getting the top blade bevelled off, and spending hours ( days ) making it...........should the two working parts of a folder be hard?
If this plate is mild ( I cant see why it wouldnt be, but I will test it ), will it be OK due to the thickness, or would a line of hardface weld be a good idea?
Old 04-29-2010, 07:34 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
What is a folder? That is a real chunk of steel you are working with and has a lot of wieght. I hope you aren't making a drag or something that could be made of RR rail. The 1" is usable for everything.
Old 04-29-2010, 07:41 AM
AJinNZ's Avatar
Sorry. After I posted I realised the mistake.
I meant a sheet metal folder. Slopdog put up some pics of his a little while ago and I was going over them again today.
His used grader edges which I assume are hardened. That got me to thinking.
Yup, it is heavy. Weighs 100 kilos so the next time I pick that up is to cut it in half. Gonna make for one majorly heavy duty bit of equipment thats for certain.
Old 04-29-2010, 08:29 AM
partsgurut's Avatar
partsgurut partsgurut is offline
sheet metal brake, I think is what he is saying. You shouldn't need to harden it, no. Mine is not hardened and works very well.
Tony
“Use it up, wear it out, make it do, or do without”
Old 04-30-2010, 12:23 AM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
I had a National brand brake at my last "real" job. None of it was hardened and It worked fine. I also, have two wooden brakes. One my Dad built and one I built. They REALLY weren't hardened.
The press-type brakes, where I spent most of my working life, did have hardened edges on the dies but, unless you're going to use it eight hours a day, all week long, I think you'll be fine, as is.
Dave
Old 04-30-2010, 12:42 AM
AJinNZ's Avatar
Thanks for the replies.
I know where I am headed now so can start getting things together, cut etc without fear of a screwup at the end.
Old 04-30-2010, 12:52 PM
slopdog's Avatar
slopdog slopdog is offline
the grader blades were use because i got them free no need for hardened steel , heres a pic of the leaf i put a torsion bar in it to get and keep it straigh
Name:	leaf torsion bar.jpg
After all is said and done ,, more is said than done .
Old 05-04-2010, 02:55 AM
jatt jatt is offline
Yeah I'm bending 4 and 5mm mild plate in my makeshift press brake (30 tonne press) without doing any real damage my home built (mild steel) upper tooling. Ok the plate I bending is only about 150 mm wide, but u get the idea. Only time I dented the edge was when I did something silly like put in a length of 10 mm rod without turning my lower V block over to a wider V opening. The trusty mill soon fixed that.
Its not a production line tool, so will last for ages without rework.
Old 05-06-2010, 12:08 AM
AJinNZ's Avatar
Thanks Jatt
I will have to be more accepting of mild steel I think. I always thought of it as inferior for 'tooling' before now.
