JR Welding Tools
Old 11-27-2016, 05:30 PM
When I built my garage, there were a couple structural issues. Ine was with some stair treads where they turned the corners. Another was with cross-bracing on some of those arch thingies, for the roof.
The inspector showed up 2 hours late, mentioned the infractions, but gave me a clean ticket with the promise I'd fix it. Of course, I told him I didn't have anywhere to go or anything to do that day, so it was cool that he was late. No biggie.
Old 11-27-2016, 05:45 PM
weldor2005's Avatar
Perpetuus Discipulus de Vita
Seeing as you are over 200' away and likely didn't bury a ground wire going back to the main, yes you need to drive ground rods. There are pretty specific rules about them now a days. Particularly that the ground cable has to be continuous and not split from one rod to the other. There is also a certain potential that they look for when measuring the rods, and if that number isn't right they will ask you to drive another, up till about 6 rods before they figure you wont get any better. All according to the sparkies I take advice from.
I ran my ground back to the main. Another thing to note, since I ran mine back to the main panel, I remove the neutral bonding screw to the ground in the sub panel. If you run a earth ground, then I'm pretty sure you have to bond the two in the sub.
David
My YouTube Channel
Old 11-27-2016, 07:45 PM
Norcal Norcal is online now
If someone only buried 3 conductors then all you can have is 120 volts, a 4-wire feed has been required by the NEC for a number of editions. The days of running 3 conductors to a outbuilding is long gone.
Old 11-27-2016, 10:34 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
I don't believe you can bond the two in the sub, only the main.
I did pull a separate ground therefor I will add a ground bar, and ground rods, but it will be isolated from the neutral. Like Mac said.
Pops, you're 1 wire short, but you probably knew that
Boise Paint Contractor
Facebook
How fortunate we are!
Old 11-28-2016, 08:31 AM
weldor2005's Avatar
Hell if I know, I ran mine from the meter, I didn't go to the Main with my Sub.
David
My YouTube Channel
Old 11-28-2016, 09:27 AM
Originally Posted by Bender View Post
... Pops, you're 1 wire short, but you probably knew that
People have said I'm a few dB down, but in this case there are three 2/0 wires and an additional ground wire.
