Old 02-25-2017, 02:31 PM
Default Welding Positioner Repair.
A good friend of mine needed his welding positioner to be repaired. So I owe
him a favor or two. So I took it and decided to take a run at it. The real
problem was the speed control was damaged and not repairable, I tried, no
luck.
So the speed control is in pictures 2 & 3. Picture one is the name plate on the
machine. My guess I that the positioner has been dropped a time or two. It
was purchased used and worked when purchased.
While I was attacking the main problem, I noticed the "high quality" welds on
the main frame, keep in mind this was manufactured in Michigan...
Pictures 4 & 5.
ID:	138006   Click image for larger version
ID:	138007   Click image for larger version
ID:	138008   Click image for larger version
ID:	138009   Click image for larger version
Old 02-25-2017, 02:43 PM
Scotts Scotts is offline
Yep the pot came apart. Can you remove that one and solder a new one on?
Or it might be a 20 dollar ebay part. Usually 120 in gets you a 90 volt dc motor. The motor probably has permanent magnets for the field and you only have A1 and A2 out or something like that.
Old 02-25-2017, 03:27 PM
Made in Michoacán?
Old 02-25-2017, 04:25 PM
Yup, you nailed it, and the 120V AC input get routed through the foot pedal first then to the speed control which has the rectifier in it some where.
Soldering in a new pot. is too much work unless the Speed control is stupid expensive, I should know Monday what parts cost.
Old 02-25-2017, 06:33 PM
Try crimping the pot back together?
Maybe they should have welded the welding positioner using a welding positioner...
Old 02-25-2017, 06:39 PM
My money is on "Stoopid expensive" for the board, and you'll be looking at
Ohmite (or other pot manuf) catalogs, come Tuesday....
The welds look to be "Hi-speed" welded....the shielding gas couldn't keep up....
Old 02-25-2017, 07:24 PM
10,000 miles ahead of you did not work.
Not my equipment, not my money...
Old 02-25-2017, 07:25 PM
I am going to test the motor with a battery first, just to make sure it is good.
Brushes are in great shape. The 2 amp fuse was also blown, so maybe the
board is fried too.
Old 02-25-2017, 08:37 PM
cutter cutter is online now
Can you see the motor plate?
Chances are pretty good that that's a 90v dc motor (though it could even be a 24 or 36 volt) so a battery may not tell you anything.
Dc motors are notoriously tough. That's probably a 5k or 10k pot, commonly available. It would be a shame to trash the board without trying a new one.
I want to go home!
Old 02-25-2017, 08:46 PM
Yes 90 volt.
There are rivets on the board, so disassembly and reassembly is not easy. Not putting extra work in to it I don't have to.
