Old 01-24-2011, 12:48 AM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
Default Project: Iron worker
OK, so I have been ruminating on it long enough and with the addition of the hydraulic pump to the score of free stuff and since 1/2 of the auto lift was destroyed. I have decided to venture out and make my own iron worker. This is something that I have wanted to do for some time but could not spend the money on hydraulic rams and pumps when I was not sure it would even work the way I planned. But when you get it all for free why not take a shot at the moon. In the past I have build belt grinders, chop saws, panel saws, but never an iron worker. I may just settle for a punch press because the shearing action might just be too much for me to make, but we will cross that bridge later.
While I was supposed to be paying attention in church today I was designing the main arm, and the general mechanics of the machine in my head. We have a 120 ton Scotchman at the school that I can take measurements and scale it down for my version that will be my own personal machine.
Question for the forum; upon inspection of the one at work it appears that the arm does not use bearings for the pivot points. It looks like they are just bronze bushings with a grease fitting. Do you think that I would gain anything by using the pillow block bearings from the dyno that was part of the free haul? or should I just use bushings?
The rams that came on the lift were 9000 lb capacity each and I am planning on using both in a parallel manner, I do not think that I will need to punch much more than 1/2 steel, and a 1" hole into 1/2 steel requires almost 40 tons. I am trying to figure out how long the arm needs to be to achieve that tonnage.
Hear is the tonnage chart I have been using;
It is on page 16
http://www.unittool.com/PDFs/Multicyl.pdf
So call me crazy for even attempting this but I have always been one to push the envelope. and I figure now would be the best time to try.
Mike
Thomas Jefferson
Old 01-24-2011, 12:57 AM
cutter cutter is online now
Wow. Okay, you're crazy. Ain't it cool?
I'm looking forward to this.
I want to go home!
Old 01-24-2011, 01:19 AM
40*2000=80,000 lb
80,000/9,000=8.888" in a perfect world (no friction losses)
You will need a frame that will handle 40 tons and arms that will handle 4 1/2 tons.
Old 01-24-2011, 01:56 AM
I would lean toward bronze or steel bushing to do better on the schock loading than bearings . Look at where bushings are still used in industrial equipment . Most big equipment presses ,rolling mills are using bushings unless it is in constant rotation during operation.
Old 01-24-2011, 02:02 AM
Barn Owl's Avatar
Splain that a bit more for me, is the 8.888" the punch side of the pivot or the ram side. And the 4.5 ton arm. I guess I was over engineering it a bit but i was thinking a stronger arm than that. But that is why I was not a math major.
Cutter, well I guess I did pull my goalie on that one. Ha
Mike
Thomas Jefferson
Old 01-24-2011, 11:20 AM
jhill
Guest
Posts: n/a
You said the rams were 9000 lbs each s0 18,000 total
40 tons = 80,000 lbs so 80,000/18,000 = 4.44
so 4.44 to 1 ratio. If you have a distance of 1 ft from pivot to cutter you will need a 4.44 ft arm to the rams.
Use bushings they will withstand extreme pressure better in low speed applications.
Jerry
Old 01-24-2011, 11:34 AM
jhill
Guest
Posts: n/a
Look at item no. 2706542723 on Ebay It is a pirana iron worker. You can see the length of the arms. They are built really stought. Overbuild everything there is a lot of pressure there. Not the kind of thing I would build.
Old 01-24-2011, 02:05 PM
You might consider building it more like a press than a piranha. Look at the scotchman 40 ton unit and the tooling that goes in the cavity.
Old 01-24-2011, 09:07 PM
Barn Owl's Avatar
I think that I will use the bronze bushings and use some thick wall DOM tubing for the race. Looks similar to what Scotchman uses.
I looked up the item Jerry sugested on ebay they are really built heavy duty, Our 120 ton scotchman does not have nearly the size arm as some of those Pirana units. But I was mostly interested in the dies you can get for $277. That is a great price. Thanks for the input guys, this will be a challenge but a fun one.
Mike
Thomas Jefferson
Old 01-24-2011, 11:40 PM
jhill
Guest
Posts: n/a
I thought the dies were really resonable too.
Jerry
