JR Welding Tools
Old 01-27-2011, 12:39 PM
wildfire wildfire is offline
Originally Posted by Barn Owl View Post
I think that I will use the bronze bushings and use some thick wall DOM tubing for the race. Looks similar to what Scotchman uses.
I looked up the item Jerry sugested on ebay they are really built heavy duty, Our 120 ton scotchman does not have nearly the size arm as some of those Pirana units. But I was mostly interested in the dies you can get for $277. That is a great price. Thanks for the input guys, this will be a challenge but a fun one.
Really interesting project. I purchased a new Edwards 60 Ton Ironworker this summer and just love the thing. As for dies. The basic round ones are reasonable but when you get into the special ones such as oblongs and square they can get pricey. Here's a few pics.
ID:	71125   Click image for larger version
ID:	71126   Click image for larger version
ID:	71127   Click image for larger version
ID:	71128   Click image for larger version
YouTube vids: http://www.youtube.com/results?searc...rch_type=&aq=f
Flickr pics:
http://www.flickr.com/photos/15602393@N05/sets/
Millermatic 350P/Spool gun
Millermatic 252
Miller Spectrum 875 plasma
Miller Dynasty 200 Dx
Rotary Table
Custom built Crazy Cart
Miller 302 Trailblazer/Custom Trailer
Sofia 12 X 30 Lathe
Craftex 30 Mill/Drill
2010 "Modern" 10X50 Mill with Fagor 40i DRO
Miller Inferno Digital Elite
Miller Maple leaf Elite
Old 01-27-2011, 03:58 PM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
Was that $593 for those four dies? That machine looks great but wow!
Gerry, I would like to see pictures of the mechanical version. The schematic did not show the action of it. Does it rotate on a cam?
Mike
Mike
Thomas Jefferson
Old 01-27-2011, 04:51 PM
Yep for the four of them plus tax. When you go for the none round ones you'll pay. After all that is the advantage to owning an ironworker is having the ability to do those type of punches. I also have a full set of oblongs as well. These things are like lathes and milling machine. There's the tool and then comes the tooling. Ouch.
I'm very pleased with the ironworker though. One of the best tools I've put in the shop.
You will see more of the punches in the video:
http://www.youtube.com/watch?v=aKUveVsNOtQ
ID:	71148   Click image for larger version
Flickr pics:
Millermatic 252
Rotary Table
Sofia 12 X 30 Lathe
Old 01-27-2011, 06:31 PM
mike van mike van is offline
If I had to justify mine by how much it's used, I couldn't. The thought was, buy it, keep it nice, and someday get most of my $$$$ back when I'm too old to get to the shop -
Old 01-27-2011, 06:52 PM
Barn Owl's Avatar
Originally Posted by jhill View Post
arn Owl
Which model Scotchman are you going to copy. Several different styles available.
Jerry
We have the big 120 ton model. makes fabrication so much easier.
http://scotchman.com/specs.php?index=7
Mike
Mike
Thomas Jefferson
Old 01-27-2011, 07:21 PM
Pat's Avatar
Pat Pat is offline
Gerry,
The mechanical ironworker you have sounds like a slick little unit. By the looks of the parts diagram you attached I am assuming it is German made (probably very good quality). Could you tell me who makes it. My Uni-Hydro is a little bit over kill for me, even though it would probably be considered light duty compared to some of the larger units. I am thinking that an ironworker like yours may be light enough weight wise that being portable would be a possibility.
Old 01-28-2011, 10:34 AM
Originally Posted by Pat View Post
Gerry,
Pat, it is a Mubea BF10F. I'm told it is 1200 lb. You can see it here
For me it is the perfect size.
I am trying to have properly sized equipment for the work I do, as there is always a bargain out there that is too heavy too power hungry, and too expensive to buy accessories...I don't want it
Herodotus
Old 01-28-2011, 10:49 AM
Mike
Not a cam, an eccentric. It has a clutch type of engagement that allows one rotation only of the eccentric, even if you hold down the control continuously. You release to reset.
It will shear up to 1/2x6 bar stock, and up to 3" angle iron.
I think in your case, using the same principal, and having a hydraulic cylinder turn an eccentric or a belcrank by only 1/4 turn, you could have a way to generate 20 times the power of a single cylinder, and have a compact unit as well.
Herodotus
Old 01-28-2011, 12:12 PM
Barn Owl's Avatar
That makes more sence thanks for the pictures and link.
Mike
Thomas Jefferson
Old 01-28-2011, 02:00 PM
dpaulson's Avatar
dpaulson dpaulson is offline
That punch/die in that Mubea is for radiusing corners of flat stock. I bought one of those last year from Cleveland tool an Die for about 350.00 USD.
I thought that I was wrong once, but I was mistaken.
David
