  #71
Old 07-02-2016, 12:24 AM
Barn Owl's Avatar
Barn Owl Barn Owl is offline
I have entered a new phase of the project, one that I never thought I was going to have to undertake. As I was mapping out the frame of the machine I was coming to the unfortunate conclusion that the hydraulic rams were too long for the steel plates that I had. Buying a new 1/2" plate of steel was out of the budget and it was also out of the spirit of this project. I really want to make this out of surplus stock that was already in stock.
The lift that the hydraulic system came out of was a Western Lift, which just happens to be about 7 miles from my shop. I made a visit to their shop and their senior hydraulic tech Pablo walked me through cutting down the cylinders to fit the project better. I really went to their shop to go over different mounting locations and in the course of the conversation was convinced that I had the ability to shorten the rams and have better geometry for the project.
So here are the steps involved in shortening the cylinders by over 20". They started out at 52" and finished length is around 29".
1. Original length
2. Cutting the original weld
3. Cut and beveled cylinder
4. All the prepped components.
5. shortened cylinder on the prepped base.
ID:	133229   Click image for larger version
ID:	133230   Click image for larger version
ID:	133231   Click image for larger version
ID:	133232   Click image for larger version
Mike
Thomas Jefferson
  #72
Old 07-02-2016, 12:38 AM
Barn Owl's Avatar
This next phase was a bit daunting because the rod is extremely hard. The hard chrome on the surface would not even bite with the file test. I had to resharpen my carbide tooling repeatedly. But in the end it all worked out and I am very happy with the end result.
1. Root pass
2. Finish weld
3. cut rod
4. milled end
5. Finial length assembled and new seals
ID:	133234   Click image for larger version
ID:	133235   Click image for larger version
ID:	133236   Click image for larger version
ID:	133237   Click image for larger version
Mike
Thomas Jefferson
  #73
Old 07-02-2016, 09:46 AM
That looks very well done Mark.
I use a zip cutter to cut the rods a little long then machine to size in the lathe.
Is that a single ended cylinder? I did not see a second port in any of the pictures.
  #74
Old 07-02-2016, 10:11 AM
Barn Owl's Avatar
Yes they are single action. I may have to put some weight on them to get them to return.
I cut them long as well then cut off the extra after the lathe work was done. I experienced a lot of vibration because of the length of the rod and the hardness of it. Once I dampened the vibration it cut relatively well.
Mike
Thomas Jefferson
  #75
Old 07-31-2017, 09:24 PM
Barn Owl's Avatar
I had to take some time off of this project to concentrate on other projects, but it is still getting put together one piece at a time (Johnny Cash).
I have maintained a friendship with my old welding instructor and eventually took his job at the weld school. he was retiring and moving to Montana and was looking to get rid of a lot of stuff clogging his shop.
I purchased a weld table from him for $1000 that has a 1.5" steel top. It was 12 feet long and 4 feet wide. the price was well within the "great deal" range. I cut the table in half so it could fit in my shop, so it is now 6'x4'. The other 6 foot slab I cut in half again so now I have two 4'x3' slabs at 1.5". These will now be the frame of the Iron worker. The 6'x4' table by itself is worth the grand I laid down for it so I am not too bummed at spending the money.
The two slabs are thick enough and are more than adequate size for the project. They will not induce nightmares as I lie in bed thinking where is it going to fail?
I have it all drawn out and I need to have a buddy of mine plot it for the CNC water jet.
The next step is an all or nothing deal because where and how it is cut will determine the squareness of the tool and axle bore, if it is of by even a little it could spell disaster.
Mike
Thomas Jefferson
  #76
Old 07-31-2017, 09:39 PM
I think you are doing well and no mistakes to this point. Congrats on the welding table, and getting the ironworker frame to boot.
  #77
Old 07-31-2017, 09:58 PM
Good luck!
I want to go home!
  #78
Old 07-31-2017, 10:49 PM
Good to hear it s still progressing. I think you are correct about the alignment of the frame parts. It does have to be right on.
  #79
Old 08-01-2017, 02:07 AM
Hey Keith,
I was curious when you wrote "to punch a 5/8" hole in a 3/4" plate..." I was always told that you should not attempt to punch thicker than the diameter of the punch. Meaning you can punch 3/4" hole into 3/4" plate but not a 5/8" hole in 3/4". Is their a different rule? Because that would save a lot of time at the drill press.
Somehow I missed this till now. I think when I made the reply I might have reversed the 5/8" and 3/4" dimensions because you're absolutely right; in normal applications you don't punch holes smaller in diameter than the thickness of the material. As you get into larger punches you could probably get away with punching the occasional "under size" hole but it will be hard on the punch and die...
  #80
Old 08-01-2017, 09:33 PM
Barn Owl's Avatar
Thanks guys I am still on it and will keep you all informed as progress continues.
Keith, thanks for clarifying that, don't worry about missing the post, this project is moving at a glacial pace anyway.
Mike
Thomas Jefferson
