Old 08-06-2017, 11:02 PM
King of Obsolete's Avatar
Published Author
after 2 weeks of soaking in a tub of diesel fuel, i dis-assembled the 2 engines. using the big sledge and wooden block i did get one piston to fly 12 feet exiting the cylinder. not bad for a guy my age, lol.
thansk
KoO
Published Author
Name:	CofR dis-assemble again aug 06 2017 018.jpg
ID:	140402   Click image for larger version
Name:	CofR dis-assemble again aug 06 2017 020.jpg
ID:	140403   Click image for larger version
Name:	CofR dis-assemble again aug 06 2017 021.jpg
King of Obsolete
Cat Train Tours
Old 08-07-2017, 08:36 AM
thansk
KoO
Published Author
That's called golfing, isn't it? When I was a kid fixing up old frozen junkers to drive, my friend and I used a fence post and the same size golf club to free up a cylinder, that was before I learned the grease gun trick.
Old 08-07-2017, 09:19 AM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
thansk
KoO
Published Author
Good thing you tied down the block, or piston and block would be over there .
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old 08-08-2017, 07:10 AM
DeepSeaDynamo's Avatar
DeepSeaDynamo DeepSeaDynamo is offline
Almost like it ain't his first rodeo
Old 08-08-2017, 09:14 PM
Published Author
yes the one td-18 known as Dually has sledge hammer piston in one cylinder.
today i got the Curse of Reverse fired up with the used pistons and went for a drive dragging the tires to get things worked in. a little blow by which is ok because i just tapped a small hammer on the rings to almost loosen them up. i only need the cat to run for a bit to test a few things out so i can order parts.
thansk
KoO
Published Author
Name:	CofR dis-assemble again aug 08 2017 007.jpg
King of Obsolete
Cat Train Tours
