JR Welding Tools
Old 07-28-2017, 10:34 PM
johnyradio johnyradio is offline
Default Do Rubber Washers Decay?
Hi
I've been advised to avoid using rubber washers, because they tend to decay/corrode/fall apart.
Can someone share experience with this issue?
thx!
(posted on a couple other forums)
Old 07-28-2017, 11:33 PM
In what situations? Under certain conditions yes, alcohol base fuels, sunlight, etc can cause them to crumble.
It depends what you are doing with them.
Herodotus
Old 07-28-2017, 11:59 PM
thx for reply, ironman.
it will be subjected to constant vibration, but not much sunlight or moisture. No fuels. It's washers in a device that will be used outside and inside, but not exposed to more than air moisture, sometimes beach air.
i'm planning on going with silicone or neoprene to be safe.
cheers
Old 07-29-2017, 08:17 AM
I would recommend Neoprene
Herodotus
Tags
rubber, washers
