Old 08-02-2017, 06:51 AM
mab mab is offline
Default Wine Rack
I need to make a couple of these wine racks. I have most of it figured out, but I'm not sure about forming the round bar. Any suggestions on how to bend 0.25" round bar?
Thanks,
Mike
ID:	140332   Click image for larger version
A tight dog is a happy dog...
Old 08-02-2017, 08:16 AM
It depends on what you have for tools. 1/4" is small enough to hand bend.
If it was me, I would find a pipe of the right size, and weld 2 ears on it with a slot for clearance for the rod. Then tuck one end of the rod under the #1 ear on one side, and wrap it around the pipe til it passes the #2 ear on the other side. Take a hammer and tap the rod up under the second ear, and then bend the rod right around in a 180 degree. This may require a torch to heat it.
Once done, slip it off the pipe and move the 180 bend to ear #1 and repeat for the next bend.
Alternative is to make a bunch of bends on the pipe cut them off, and weld them together to form your rack.
Old 08-02-2017, 06:48 PM
I would figure out the total length, and roll or wrap the round bar in a continuous loop, then just heat the sections to back bend the U.
Old 08-02-2017, 08:05 PM
mab mab is offline
Gentlemen,
Both excellent suggestions. I think I'll try the coil idea first. I'll let you know how it goes.
Thanks,
Mike
Old 08-03-2017, 05:25 PM
FWIW, when it am making complex bent parts, I usually bend light gauge stuff first as a trial run. You can take a piece of tie wire, put one end in the vise and jerk on the other end with a pair of pliers. This will make it straight. Then roll your loops, then bend the U shapes. It gives you a good idea of the process, then you just need to add more pressure or heat..
Old 08-03-2017, 08:07 PM
mab mab is offline
I was wondering if that would work. I have some solid 12 ga copper I thought I try a piece of that.
Thanks,
Mike
Old 08-03-2017, 09:30 PM
NOBLNG NOBLNG is offline
Similar to the first idea, you could weld four 5/8" nuts to an appropriate sized pipe. Slip a piece of 1/2" rod through one set. Insert the 1/4" rod and bend it around past the second set. then insert a second 1/2" rod and reverse the bend. Then pull the rods out, move it over and repeat.
Old 08-05-2017, 03:42 PM
mab mab is offline
Another good idea. I'm still looking for an appropriate sized piece of pipe in inventory. Nothing yet.
Thanks again for the suggestions.
Mike
Old 08-05-2017, 05:40 PM
camdigger's Avatar
Roving Reporter
Mike
If you are only working with 1/4" rod, I would seriously look at a simple wooden form. For example, I bent up four semicircular pieces out of 1 1/4" square tube using a circle of wood screwed to a scrap of 3/4" plywood from the subfloor of my house build.
A strategically placed bolt would work to do the reverse bend.
20$ should get you a flycutter for a drillpress you can use to cut the disc for the form. A cutout from a 4" holesaw will work too.
I could sketch up a schematic using Amish cad if you like. I could even make a jig and photograph the process given a few days....
Old 08-06-2017, 10:21 AM
mab mab is offline
Cam,
Thanks for the idea. I think I found something that will work.
Thanks,
Mike
ID:	140387   Click image for larger version
