JR Welding Tools
Old 07-07-2017, 02:02 PM
Default Dodge
My son gave me his 2015 Dodge 1500 to use well he is out of country for three years, and that he would keep it insured and licensed for me I have never owned a new truck before and it took some time to figure out all the do dads and such. Two weeks ago the air conditioner quit so its still under warranty so the Dodge dealer found a leak and fixed it. I get the truck back and find that I have no heat I take it back in and they replaced the heater core and the thermostat and now they tell me that they have no idea what is wrong with it and that they are going to contact the engineering at Chrysler and will get back to me. WTF They did say that they had to remove the dash to fix the air.
Old 07-07-2017, 02:14 PM
Sounds like they unplugged or jarred a wire loose.
Old 07-07-2017, 11:39 PM
THIS! ^^^^^
Once upon a time, you could remove a dash pad or instrument cluster by removing a few screws or popping a few clips. The hardest part might be reaching behind to disconnect the speedo cable. Simply remove the glove box and its door to get the heater core out. Reach behind the cluster to replace a turn signal bulb.
Nowadays, the dashboard of a vehicle is a VERY complex assembly, requiring a very specific procedure to remove it or anything housed in or within it. Deviate from this procedure and things get broken.
It is not uncommon for a dash to incorporate a wiring harness or printed circuit or both. This buss (or bus) connects all the various modules and processors that control many functions such as HVAC, airbags, instrument display, stereo, lighting and so on. If it is electric in a car today, there is probably a module that controls it. And all these modules are interconnected by the buss and share data that way. If they damaged the buss that connects to the HVAC it could have resulted in your issue.
Old 07-10-2017, 01:41 PM
Now they are going to change the water pump I asked him if they always changed water pumps when the heater is not putting out heat, I said that it doesn't make sense. He said all they can do now is what Chrysler says.
Old 07-10-2017, 03:41 PM
moose's Avatar
moose moose is offline
Good luck!
FCA/Cry sler also says that they find it acceptable for the Dart with a 2.5 multiair engine to consume a quart of oil every 750 to 1000 miles on an engine with only 50,000 miles!!!
moose
Southeast Michigan
https://www.facebook.com/Metalcraftbymoose
Old 07-10-2017, 07:27 PM
Windy_Acres's Avatar
Chairman of the Headboard
This one is scary,,,,.... Tell them to check and see if there is too much gas in the fuel system, I heard that can cause problems too !
Edit, I should mention, back in the day, when I had my own garage, 3 different body shops used to bring me the mechanical work, their guys did not want to do, about half that work was putting new dashes in mostly from deployed air bags, and of course on almost brand new cars, ( blown bags in anything about 4+ years old is usually scrapped unless it was ultra expensive ). That being said, that is why I find this scary, I have " some " knowledge of whats going on here.. they have the info and the tools to figure it out, but sounds like they might be short on personnel to put it all together,...
Whiskey bottles, and brand new cars, Oak tree you're in my way....
Old 07-12-2017, 12:04 PM
I would say theybshould entirely strip down the cooling system to confirm there are no more of those and see what they say.
Time for a new signature line!!
Old 07-12-2017, 12:10 PM
Where is the rest of the gasket? and if a piece is that big where is my next leak...
(yes, someone doctored it so they can claim they found it...)
Old 07-12-2017, 01:37 PM
Bender's Avatar
Bender Bender is offline
One Lone Sub
It looks like the dealer is trying to keep the lights on by billing 'warranty' work back to Dodge.
Boise Paint Contractor
Facebook
How fortunate we are!
Old 07-12-2017, 02:26 PM
That dab of silicone looks too clean to have been obstructing coolant for a while. When was it changes last? Was it this way since new?
