Old 12-21-2017, 10:44 AM
Scratch Scratch is offline
Default Magnetic drill for fab table
I'm looking to drill about 60 holes in my one inch thick 4'x6' fab table. I think I'm going with 1/2" holes, but may end up going with 5/8" holes instead. Do places rent them, or am I going to have to buy one? Will a new bit hold up to that many one inch holes?
Old 12-21-2017, 12:01 PM
I don't know if they rent them, but not around here.
Will the bit stand up?
That depends on the operator quite a bit. If you set up a coolant feed with the bottle supplied with the unit, and ensure your steel is clean and rust free, probably will. If you overfeed, expect some tip breakage.
There are units like a Hougan that have auto feed, which is good for this kind of exercise, my drill is a low cost($400) Chinese unit so I don't have autofeed, but it's not rocket science, you can tell when the bit is happy.
Herodotus
Old 12-21-2017, 01:21 PM
My Hougen doesn't have auto feed, but Gerry's right; you don't NEED it if you pay attention. I've cut holes from 7/16" up to 1-1/2" through steel from .095" up to 1" thick with mine, mostly 1/4" wall tubing.
Some of my cutters have seen probably over 200 holes, mainly 1/4" thick, and are still as sharp as when new. I tend to keep loose track of that by how many seconds it takes for a particular size hole (yeah, tiny bit of OCD here )
Hougen recommends you do NOT baby the cutters or run dry, but instead use enough down pressure to load the drill down audibly. Works for me... Steve
Oh, also - if you're drilling 1" material, do NOT buy a 1" depth of cut cutter - might work, but 2" DOC is only a few bucks more...
Old 12-21-2017, 02:11 PM
I was with Ironman, but I see they do rent them. Not a bad rental fee either.
Old 12-21-2017, 02:40 PM
Gonna run a tap down thru them when done ?
Old 12-21-2017, 02:41 PM
All the rental places around here have them. Of course there has to be a rental outlet within a reasonable distance or it doesn't do you much good. We've got 3 or 4 places within a couple miles--nearest one is about a half mile away.
A good quality drill should do 60 holes without a problem--maybe touch up the cutting edges half way through. I'd use a good cutting oil if I were tackling that job...
Old 12-21-2017, 03:23 PM
Try Home Depot.
may have to call more than one I was asking about a sewer cam and they told me only one HD had one that was broken.
I did see some large drills that had carbide/diamond cutters for drilling concrete post holes. cant say if they had magnetic bases but likely.
Old 12-21-2017, 03:47 PM
No. I'm planning on just a simple grid of holes. I want to use pins and clamps like this setup:
https://www.youtube.com/watch?v=iDRc6m3D7sU&t=604s
Old 12-21-2017, 05:20 PM
I have done 300-400 holes with a good quality cutter, through 3/4” plate.
Old 12-21-2017, 06:37 PM
Good, I was imagining you chasing BB's out of threads for ever
Herodotus
