Old 12-21-2017, 06:48 PM
Good, I was imagining you chasing BB's out of threads for ever
That's why you plug the holes with allen head socket screws.
Old 12-21-2017, 06:51 PM
There is not a lot of clamping force in a home made 1/2" HR round clamp. Take a look at some of the commercially available clamps and size your holes for those.
Old 12-21-2017, 07:27 PM
Scratch Scratch is offline
Thanks for the advice.
Old 12-31-2017, 10:06 AM
Drilling 100 or more 1/2" diameter holes through 1" mild steel can be done with a quality HSS twist drill, even without coolant or re sharpening, I have done this several times.
The trick is to start with a sharp drill, proper feed and spindle speed. The idea basically is to keep the drill cutting into relatively cool steel. The drill should advance into the hole close to the same speed as the heat is conducting in it. My experience with beginners is they tend to be light on feed pressure. Get everything right and you won't have to MESS with cutting oil.
My fab tables all have 1/2-13 threaded holes. I often use standard machine table hold down tooling to fixture the work. I can also easily make custom fixtures with readily available bolts and threaded rod. With a machine tap you could cut the thread using the same set-up as drilling. Tapping a 1/2" hole at 500 RPM can also be done with a bit of practice and cutting oil.
The hole spacing is also standard in my shop. This way I can use fixtures anywhere including my machine table and the rear bumper of my service truck.
We are Borg but we don't know it.....yet. We are being assimilated but we don't know it.....yet. Resistance is not futile.....yet. Are you and your children "connected".....yet?
