Old 08-19-2017, 06:25 AM
LW Hiway's Avatar
LW Hiway LW Hiway is offline
Lord of the Minions
Today I decided to tackle the front bleeder screws as I was going to be working at that end of the truck anyhoo.........oil,filter and grease 'em up.
As often as I change eng oil and filter etc and grease the front suspension and drive line, I check the bleeder screws taking the time to repaint the threads with anti-seize on each all round.
Nothing worse than having to drill out one or 4 of those sumbitches due to heat, age and corrosion.
Collector of, shooter of and builder of "TightAir Guns".
I take on faith that a Twinkie will explode in a Microwave Oven with an average time of 45 seconds.
Old 08-19-2017, 09:07 AM
We would all be better off if we did more preemptive strikes instead of waiting for challenges. Usually, most of us are better at procrastination.
Old 08-20-2017, 11:32 PM
cramd's Avatar
cramd cramd is offline
Drivin' Fool
Guilty as charged, at least now that I am getting older and creakier .
Miller Thunderbolt XL AC/DC
Hobart Handler 190
Old Yesterday, 07:48 PM
Pontiac Freak Pontiac Freak is offline
Default Things that have worked for me
I have had the opportunity to experience the fun you are describing once or twice. Things I have found to help. I use a brass drift and smack the bleeder several times before trying to loosen it, this usually will help break it loose. I also will depress the brake pedal and put a bar/stick etc against it keeping it to the floor while the brake system is open. This eliminates the continuous leaking from the open port and keeps air from entering the system. Easy to bleed when done. Your mileage may vary :-)
