Old 05-06-2017, 01:17 PM
jimkinney jimkinney is offline
Default Lawnmower Epic Fail
About half way through mowing the back yard and this happens. Ten year old Craftsman, garage kept, only used on the weekends, should of got more life out of it.
Hammered the pieces flat and hammered them together and broke out the welder.
Welds aren't the best, almost out of gas, windy and I'm rusty, mostly I'm rusty.
I pulled the other side apart and it needed welding too.
Cleaned it up and sprayed some new red paint on it and I'm back in business. Hopefully get another ten years out of it.
Jim
ID:	139250   Click image for larger version
ID:	139251   Click image for larger version
ID:	139252   Click image for larger version
ID:	139253   Click image for larger version
Old 05-06-2017, 05:53 PM
Do you wash the underside after every mowing? I sprayed mine with automotive undercoating. Helps protect the steel from rusting.
β€œIn order to become the master, the politician poses as the servant.” Charles de Gaulle
Old 05-06-2017, 05:58 PM
Good repair I have done the same.
Old 05-06-2017, 06:26 PM
That is what happens when you mow wet grass and don't clean and dry the machine. Now in NM (and probably in WY) it's never that wet to cause a problem. :-) Back in PA it was like that. :-)
...lew...
Old 05-06-2017, 07:10 PM
rmack898's Avatar
rmack898 rmack898 is offline
That HURT!
They sure don't make them like they used to. Good fix, but next year you will have to do the back wheels.
Mac
One extremely happy (but now prospering) lucky bastard Years ago, I might have been called a patriot, tomorrow, I might be called a criminal.
Old 05-06-2017, 07:30 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
I've done the same repair on my old pusher....except I welded a 4"x4" piece of plate over it after the patch was welded, re-drilled the holes. I think I did all four wheels at the same time.
We are all given many opportunities in life to keep our mouth shut.....we should take advantage of as many of those opportunities that we can.
Old 05-06-2017, 07:52 PM
RED caddy's Avatar
Da Chief
Here on the sand spit, we very seldom keep a deck long enough to see that kind of failure. The sand we have to grow grass in just sand blasts the metal out of the volute, until the engine just falls off.
On my longest running rider, I picked it up used, re built it and had the deck Rino Liner coated, top and bottom. (A buddy bought a franchise) It's an old Massy-Furgeson, going on it's 11th season on that old deck I weld repaired and coated. 2 engines, jackshaft replacement and a tranny rebuild later, the deck is still kickin. Now THATS undercoating.
RED
Old 05-06-2017, 11:05 PM
Nice save. my lawn mower deck repairs always look crappy, I just blame it on the contaminants in the recycled metal.
Old 05-07-2017, 07:40 AM
Hi guys,
Thanks for the comments.
Yes I do spray it underneath after each use. The well water here used for irrigation is brackish (salty) and part of the yard is along a salty pond. Red is correct about the sand under the grass also. I should have undercoated it, maybe the next one.
Back wheels attach differently to the side and back, but have had to do minor replace bolts back there.
Thanks,
Jim
Old 05-07-2017, 04:46 PM
Silverback's Avatar
Silverback Silverback is offline
10 years?
Around here it doesn't matter how you take care of it a modern mower doesn't last that long without repairs (though I know of 30y/o "cheap" at the time mowers that look better than my 5y/o craftsman).
The John Deere that I had before my craftsman the deck rotted out around the volute around the engine at about 8 years so bad that there was nothing to weld back together and for a while I just taped it back together with aluminum tape and painted the top side green and the bottom side got a heavy coat of truck bedliner and I got another season out of it.
For the most part I've gotten so tired of the quality of current reasonably priced mowers (say under $350-400 last time I shopped) that I've taken to looking for a good one on clearance/lightly used that matches my criteria (self propelled rear drive) for half price or less when mine starts getting annoying to repair, usually I find a new one that was assembled wrong at the local Sears for less than 50% of the original price within a year or 2. I need to start looking for one for this 5y/o craftsman, honestly the deck on this one is not too bad yet, but the stupid automatic choke design drives me crazy (a plastic arm that goes under the heat shields near the exhaust that melts in less than a season), it uses a bunch of oil and the drive is slipping badly. Stuff that is fixable but after a while it's just not worth doing repeatedly, it will limp along like this for at least a year or 2.
Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
BFH
