Old 01-22-2009, 06:53 PM
Hurricane Hurricane is offline
Default Aluminum mig question
I just started mig welding aluminum today with decent results, but i have a few questions you guys may be able to answer for me. decent looking beads w penetration once i get moving, though i dont seem to have enough amperage to penetrate from the start, have to get some heat in it first.
my setup - 145amp machine, turned all the way up
5356 filler wire .030, 3/16" 5052 plate, 25cf straight argon
1- how fast should my wire speed be? the machine has a 1-10 dial, best results have been at 7, any slower and i get a lot of burn back, sticking the wire in my tip
2- how much stickout should i use?
3- im getting a HUGE amount of white smoke while welding, is this normal or am i doing something wrong? looks like welding galvanized steel, is this going to make me sick?
4- can somebody explain what spray transfer is? dumb it down for me if you can
i also bought a roll of 4043 wire, but have trouble getting it to feed. will try again once my teflon liner and roller get here. thanks
Old 01-22-2009, 07:22 PM
pumpertruck's Avatar
pumpertruck pumpertruck is offline
Spinner of Wood
It's been a few years since I have run aluminum so I am a bit rusty. I can't help you on the settings although a 145 amp machine may be a bit on the small side. I ran with 600 amp capacity. We ran with 1/2" stickout. The white smoke is normal. Don't breath too much of it. Spray transfer is when you get the voltage higher. I think I ran .035 at around 26 volts. If you want to cough up the extra money you can run a helium/argon mix for a lot hotter arc. If I remember right, 4043 is a softer wire and doesn't feed very good unless you have a push/pull feed system. Most of my aluminum mig was running .045 or .062 on 1/4 to 4" thick stock. Like I said, it's been a few years.
Shorter of breath and one day closer to death.....
http://www.ibrbsantas.org/
Old 01-22-2009, 10:41 PM
Default Some like it hot...
I'm sure many of us here will tell you that you are potentially spinning your wheels trying to weld aluminum with a MIG gun, teflon liner and "weak" machine. Aluminum needs a lot of heat (amps). And I (we) speak from experience--been there, didn't do that because it didn't work all that well.
The scenario is that in order for the wire to feed and not birdcage you need a stiffer wire (5356). Right off the bat, 5356 needs about 15% more amps than 4043 to weld properly, hence, your machine is "turned up all the way". You may never get enough heat into the work to get good penetration, especially 3/16". You might do OK on thinner gauge. I don't think the liner will help you that much with 4043--the MIG gun has to remain nearly straight, especially with a thinner wire.
This is not to say that it can't be done--maybe try some pre-heating of your work with a propane torch? I can't help you with your settings.
A good rule of thumb is to not breathe ANYTHING coming off of the weld. Hold your breath or use a respirator. I can't explain the white smoke...maybe normal?
Normal MIG welding is done with the "short" method (vs spray). The filler wire contacts the work piece, shorts out, heats up like a lightbulb, then melts into the puddle. This is continued over and over again while the trigger is squeezed.
With spray arc, the filler wire melts BEFORE it reaches the workpiece and is deposited in smaller drops but at a higher rate. This process requires much more power and is used on the larger, higher-end machines.
Read the attached pdf courtesy of Miller--it is a little more descriptive of the various processes.
Old 01-23-2009, 07:29 AM
How long can you hold your breath. lol
The smoke coloration won't always be the same, but that's about the closest description.
Hurricane, if you do a search on here back to about 3 years, you'll read more threads than you have time to sit through on some very specific information dealing with MIG and aluminum.
Your machine is pouring it's heart out for you working that 3/16" Al. Your starting beads will be just as you mentioned, unless you possibly do a little preheating where you start.
Old 01-23-2009, 12:31 PM
obviously i try not to breathe any welding fumes, just wanted to make sure that was normal. im not welding anything that needs to be strong, just good enough to hold together
Old 01-23-2009, 04:01 PM
DrBob's Avatar
DrBob DrBob is offline
Default Welding Aluminum
Hurricane, as has been said you are at the very top of your machine's capacity. I think you will have better results welding thinner stock.
You should be welding with pure Argon gas. If you do there won't be any appreciable smoke. You have to turn the voltage and wfs up to get out of short/circuiting or globular transfer to spray transfer. Instead of the 'frying bacon' sound you will hear a loud buzz. BTW you can only spray transfer in the horizontal position (not vertical or overhead).
Most find that pure aluminum wire is too soft to feed through your regular gun and switch to a spoolgun. This has the wire right in it and since it only has to feed a few inches it won't birdsnest. Other tricks I have learned are to increase the stickout a bit and to move faster than when welding mild steel.
Also turn up the shielding gas to as high as 30-40 CFH. As I said pure argon.
Not C25. As always, PRACTICE PRACTICE PRACTICE! I would also clamp your coupons (sample welds) in a vice and try to bend them apart. You might be surprised when some of those 'good looking' welds just fall apart because of poor penetration. Aluminum is such a good conductor of heat that it takes more heat than mild steel.
Good Luck
DrBob
Old 01-31-2009, 02:37 AM
Gadgeteer's Avatar
Hurricane,
I'm wondering how the aluminum melting is going for you. Just thought I'd pass along some info about my new experiences with it. I have a 120 volt, 90 amp, Century that has served me well for several years, and a few months ago thought it was time I tried aluminum. So, I tried both 5356 and 4043, 0.030 wire, and found that both would drive just fine through my 5' cable and gun, and hasn't nested, yet. I didn't even bother to change to a teflon liner.
My photos show what I deem to be glob transfer and spray on 1/8" coupons. Both were done with the voltage at the highest setting, then playing with wire speed. When in the glob mode I looked under the nozzle and could see individual globs forming on the end of the wire, which would then drop off, forming overlapping globs at the joint. When in spray the glob transformed into a fine mist, which was then, miraculously, deposited at the joint. I can see why the spray can't be done out of the flat position, due to lack of control. Hammer tested both with the results shown.
Now, my results may not appear to be like that achieved with larger machines, but for what I want to do, I like it.
Name:	Glob Transfer.JPG
ID:	41029   Click image for larger version
ID:	41030   Click image for larger version
Name:	Alum Coupon Test.JPG
Old 01-31-2009, 06:39 PM
contrary to popular belief, i didnt have any problems once i got the hang of it. turning the argon to about 40cf made a real big difference. i tried breaking some welds and just deformed the coupon, so theyre plenty strong.
Old 01-31-2009, 10:06 PM
Team DeSade's Avatar
Team DeSade Team DeSade is offline
Send a message via AIM to Team DeSade
Gadgeteer, that's pretty impressive given the equipment used. It encourages me to give it a try with my 110V MIG.
Terry
Old 01-31-2009, 10:17 PM
Gadgeteer's Avatar
Thanks for the good words. That's what it's all about... getting the most out of the tools we've got.
