JR Welding Tools
Old 05-29-2017, 10:48 AM
Rufus Rufus is offline
Default Double fan cooling system
Hi all:
I built this project on the spur of the moment. The idea came from a weld shop foreman that I use to work under. He built the same thing, but used thicker steel. The "H" frame that you see came from behind the garage at church founded by my son and I was there cutting the lawn. In the first picture you see the lower box fan mounted to the frame by plastic zip ties. in the second picture, you see where I have a piece of galvanized angel held in place by two "C" clamps ready to weld. The third picture shows everything set up to commence welding. I sat the project near the garage door and a box fan blowing all the smoke out so I wouldn't get sick. The fourth picture shows the finished product. Took maybe 25 minutes from start to finish. I have included a link to the video I made of it for Youtube channel, "Tim's Tinkering Area" For some reason I can't seem to communicate very clearly when in front of the camera. I will often repeat myself. What I need to do is have some sort of a script made up so I can apply it.
https://www.youtube.com/watch?v=fpb67P4LYMU&t=45s
Thanks
Tim
ID:	139544   Click image for larger version
ID:	139545   Click image for larger version
ID:	139546   Click image for larger version
Name:	Frame 4 finished product.jpg
Old 05-30-2017, 09:26 AM
Nice, looks like old bed rail that every one hates would also be a good choice.
Old 05-30-2017, 12:04 PM
Thank you very much I really appreciate it.
Tim.
Old 05-31-2017, 10:08 AM
Mild Steel's Avatar
Mild Steel Mild Steel is offline
I like it. Simple and effective. However, the "Tim the Tool Man" gene in me wants to see a quad fan version
Still trying to be the man my dog thinks I am.
Old 05-31-2017, 02:04 PM
To be honest with you, I have been giving it some thought that in the future, I want to make one that has 12 fans. Perhaps overkill, but more fun to build and a lot cooler (pun intended )
Thanks
Tim
Old 05-31-2017, 07:02 PM
biker55's Avatar
biker55 biker55 is offline
Hello, just saw this. what's the purpose of having two fans mounted this way? is it to provide cooling or to dry something? or is it for some other purpose?
Old 06-01-2017, 01:21 PM
It's just basically used to cool me off. However, if I have a shirt sopping wet from working out in the Tinkering Area or from being out gathering scrap metal or aluminum cans I can spray the shirt down with fabreeze and hang it in front of the fan to dry it off. To be honest with you, I had more fun making it than I do using it
Thanks
Tim
Old 06-01-2017, 02:18 PM
I have put a 20x20 furnace filter in front of those fans before for a cheap smoke eater. Or when painting inside. It can help clean the air, and you can pick how good of a filter you want to put in it. Just don't put it real close to sparks from the welder or plasma cutter.
Old 06-01-2017, 07:07 PM
arcflash arcflash is offline
I did that with a large box and some filter material to make a poor mans paint booth. Works well and folds up too!
Old 06-01-2017, 09:15 PM
I have thought about making some sort of paint booth attachment for the upper fan on that project. It might be the "poor mans paint booth" but hey!!! If it works, it works!!
Thanks
Tim
