Old 05-10-2016, 07:27 PM
Scrapper Greg's Avatar
Default Compressor rehab
OK. about 15 years ago, I bought a "Professional grade" 60 gal compressor. Well let me tell ya, it aint no professional grade about it. If it has 100 hours on it, I'd be lucky. It has one of those oilless compressor setups on it. It sucks. Period. I have replaced rods and cylinders in it 2 or 3 times. I have officially given up. Soooo, I got a 5hp Marathon motor and the big HF compressor. This HAS to be better. So I started building my motor/compressor mount. Its around 3x3x5/16 or 3/8 angle. I hope this is heavy enough......... I truly believe that I will have to put a ring on top of it to lift it and the motor and compressor on in one unit. Pic 1: Whats being replaced
Pic 2: New mount
Pic 3: Compressor holes drilled and tapped.
ID:	131554   Click image for larger version
ID:	131555   Click image for larger version
MAGA
Old 05-10-2016, 07:49 PM
What psi is the HF compressor?
Old 05-10-2016, 08:26 PM
Says its 145 in the book. Forget what the cutoff is on the switch. Its been so long since I ran it.....
MAGA
Old 05-10-2016, 08:49 PM
Should be a great upgrade..
The HF compressors heads can be pretty good..
_________________
Jennifer
My google+ page
DoALL 36"
Old 05-10-2016, 09:14 PM
cutter cutter is online now
Is that pressure switch going to be able to handle a 5hp motor?
I want to go home!
Old 05-10-2016, 09:40 PM
It should (?!?) The original motor was rated at 6.5. Might be subjective there. Just like the professional label. But if it releases the magic smoke, I guess I'll swap a new one on. I'll check the rating on it tomorrow.
MAGA
Old 05-10-2016, 09:59 PM
Greg, I'd worry about bending that angle iron lifting it like that.
Be careful welding to those tanks. They are thin, built to the standards of the compressor they used.
The Cast iron Chinee heads are very durable, you should be fine there. The pressure switch will handle 5hp, but it's life will be considerably shorter. The contacts burn over a couple of years.
If you install a relay, it will be switching .01 amp and last til it mechanically fails. A mag starter is the expensive way to go, but relays start at 3 bucks, and go up. Here is an example of a mid range one you can mount is a spare electrical box.
Herodotus
Old 05-10-2016, 10:10 PM
I will be wearing steel toe boots when lifting that setup, just to be safe.... Tank itself will not be welded on. If I need to weld, it will be in the "shelf" that the motor is bolted to. I marked that relay. And will dig into that soon.
MAGA
Old 05-11-2016, 12:04 AM
The reason I mentioned it is I've read/heard of them welding themselves closed when they're overloaded. That can be pretty scary and expensive.
I want to go home!
Old 05-11-2016, 01:46 AM
Cutter, I hadn't heard of that. I think I'm going to work on something like Gerry mentioned with the relay. That way it will take the load off of the pressure switch.
MAGA
