Old 01-15-2017, 04:36 PM
yooper yooper is offline
I'll try to explain this without a picture , where the AC goes to the common point of two diodes you see that the arrow on one diode points one direction and the other diode is opposite direction , this is why you would need 2 reverse polarity diodes , one for each AC input lead -by reverse meaning the threaded end of the diode is opposite polarity of the other diode .
Clear as mud , eh ?
Old 01-15-2017, 04:48 PM
Rufus Rufus is offline
Clear as mud , eh ?
Is that how I have it in the diagram I drew?
Thanks
Tim
Old 01-15-2017, 04:53 PM
How do I upload a image from my computer ? The insert image icon wants to do it from a url link ?
After you write your post go below to manage attachments and use that to attach your pics.
Old 01-15-2017, 04:59 PM
Scroll down below your message window, click the Manage Attachments button.
This opens a little window of your computer hard drive that works about like Windows Explorer.
Click the top "Choose File"
Navigate to your picture & click it.
In the lower right corner of the attachments window click "Upload" & wait a few seconds. A thumbnail of your picture should appear below the typing window.
Remember to close the manage attachments window when you're done.
Housekeeping Staff
If Ă˜bama had a son he'd look like Mohammod Abdulazeez.
Let them eat hope.
Old 01-15-2017, 05:01 PM
MAC702's Avatar
MAC702 MAC702 is offline
set phasers to .50 caliber
For a full wave bridge rectifier he will need two separate heat sinks if he has 2 forward and 2 reverse diodes , if the diodes are all the same polarity he will need four separate heat sinks .
Why? That doesn't make sense to me.
A heat sink is a heat sink, not part of the electrical circuit (except probably grounded to chassis.)
Isn't this an example of one on a single heat sink?
Old 01-15-2017, 05:05 PM
Originally Posted by MAC702 View Post
Why? I'm going to do some research but that doesn't make sense to me.
A heat sink is a heat sink, not part of the electrical circuit (except possibly grounded to chassis.)
I don't deal with a lot of components like this, but I'm pretty sure I've seen a lot of full-wave bridge rectifiers mounted on a single heat sink.
I don't have that kind of bridge rectifier. I am using 4 separate diodes like this one here. That is why I need 3 different heat sinks. One for the 2 bottom diodes as in the drawing and 1 for each of the top diodes.
Link to the kind of diode I have ordered.... http://www.ebay.com/itm/150A-POSITIV...-/261092065367
Thanks
Tim
Where diode is bolted to the heat sink is part of the circuit , the base of the diode is " hot " .
Old 01-15-2017, 05:12 PM
MAC702's Avatar
So in this case, that diode's heat sink would be insulated from the chassis. Okay that makes perfect sense. That's the key I was missing in my tired brain. Long afternoon. Guess I never thought about how those big diodes were mounted before. Duh.
Old 01-15-2017, 05:17 PM
I could make the enclosure out of mild steel but have the heat sinks insulated from the enclosure, perhaps mounted on some wood.
Thanks
Tim
Old 01-15-2017, 05:41 PM
Smile
Thanks
Tim
Or .. you could put those diodes on the shelf , take the easy way and order that bridge rectifier that I linked in your other post
