Old 02-26-2017, 07:04 PM
Default Syrup stove
Made a maple syrup stove for a friend and some stainless steel pans. Here are some of the build pics.
He had started cutting the stove apart himself and then asked for some help. I took over from there.
ID:	138074Click image for larger version
ID:	138075Click image for larger version
Old 02-26-2017, 07:10 PM
More pictures. Made an alum chill block with argon back purge to help weld up pan corners. Worked great, as long as I remembered to turn on the back purge!
ID:	138081Click image for larger version
ID:	138082Click image for larger version
Old 02-26-2017, 07:14 PM
More pictures. Friend was really happy how it turned out so far. I think I need to build another pan for him, as he is trying to tweak his system. I will try to get another picture of him boiling someday.
ID:	138084Click image for larger version
ID:	138085Click image for larger version
ID:	138086Click image for larger version
Old 02-26-2017, 08:50 PM
Looking real nice.
Old 02-26-2017, 09:20 PM
Gadgeteer's Avatar
I'm thinking waffles. I like to add maple and chokecherry syrups 50/50.
Old 02-27-2017, 04:43 PM
Looks pretty good! The back pans remind me of one I made last year.
https://youtu.be/fkuES4U5cPg
I thought about building a couple more to try selling this year but it looks like syrup season is already started now.
Old 02-27-2017, 09:54 PM
base, yah that pan is real close to what I made this year. Those pans are 24" square by 8" tall. He did not want any lips bent on them, or drain, but he is rethinking that now. :-) might be modifying them next year for him.
I bent up two opposing sides in a brake, and then bent the other two sides as much as possible, and finished the bends in the hydraulic press. Worked out pretty good, and only had to weld the vertical corners.
Luckily the boss had an order for a sap pan himself, so I made that one first and got warmed up for welding, and managed to build those two pans in about three hours. I think the first one took me about three hours by itself, but that one had 1" lips bent out at the top and a drain pipe put in it also.
Old 02-28-2017, 01:15 AM
Yeah, same thing with the guy I made my pan for- he didn't want a lip at the top. Personally, I recommended doing a lip because I think it had a capacity around 40 gallons so I liked the idea of extra rigidity but he was kinda minimalist. Had to talk him into the drain port too. He thought it was no big deal to ladle the syrup out but I eventually got him to go for it.
I also did an aluminum purge block. I taped it into place with aluminum tape and it worked great for welding it also made it easy to tack up the square corners under purge. Definitely the way to do it.
Old 02-28-2017, 07:03 AM
weldor2005's Avatar
Perpetuus Discipulus de Vita
Okay, I've looked at that "Purge block a couple times now, and I only see two larger holes in it. Did you drill any porting holes for the argon to get to the Stainless?
David
My YouTube Channel
Old 02-28-2017, 07:08 AM
There is one hole that the argon flows into, the outlet is in the corner of the block. I rounded the corners of the block where it would meet in the corners of the pan. The argon then can flow out the space between the alum rounded corner and the square corner of the pan.
By clamping the stainless to the alum block with vice grip, it allowed me to adjust the fit with a hammer too. There was enough argon flow to keep the back side of the weld from sugaring.
