Old 03-11-2017, 11:45 AM
Here you go, Rufus ...
Old 03-11-2017, 12:18 PM
Rufus Rufus is offline
Lol if only
Thanks
Tim
Old 03-11-2017, 09:54 PM
Originally Posted by Rufus View Post
Hi all:
Once again I have to say "I don't know if this is correct place to post this, so if it isn't please forgive me". I saw a fellow on Youtube (kevin caron an artist) in a video showing how to cut slits in metal with a 4 and a half inch angle grinder then bending it around to the shape you want it to form. In the following pictures I show 1) the slits made and the metal bent, 2) slits welded up (can you say pelican droppings?) 3) welds ground down and a shot of the finished product from the top and 4) shot of the finished product from the side. The welds were laid with 1/8 inch 6013 on 85 Amps DC+. If I were to attempt this again, I would try a 3/32 inch rod.
Thanks
Tim
I have done something similar in the past. The way I did it was to score my lines the entire length but not cut all the way through. Then avoid full penetration on the weld and only one side required grinding to look nice.
Old 03-11-2017, 10:31 PM
I see what you're saying. It seems to me that the method you pointed out would be good on thick steel (perhaps 3/16 inch and above). Also the method you described would have saved me a ton of welding and 1) the welds would have looked better and 2) grinding would have been a lot easier.
Thanks
Tim
